RCA 27 tube tv...half screen is fine and half screen is all black lines
    Sergeant:
    Champion:
  • 375 Answers
Vertical problem,possible ic and caps
Posted on Aug 25, 2008
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
2002 27" SONY Trinitron. Half-screen picture with bright line.
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Phillips 27" flat tube tv
go to menu. u have a horazontel problem
Feb 07, 2008 | RCA 13R400TD 13" TV
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Tv turns black and white
No, the tube is not bad. There are a couple of very small surface mount components mounted by the main microprocessor that could be causing what you are seeing. They are very small and quite hard to unsolder and replace without losing them. The set should be serviced by a qualified tech familiar with the new RCA chassis.
Aug 21, 2007 | RCA F27650 27" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA 27" F27189ET HOME THEATRE - No picture
Is unlikely the picture tube is bad,the description of the problem tells me you have a straight line from top to bottom that is an indication of a horizontal deflection problem and is correctable and inexpensive,just in case the line you mention goes from side to side the problem will be in the vertical circuit and is also repairable.To make things easier tap the set on the side just to see if it reacts,don't over do it ,if it does the should be a lot less expensive because it might just be loose conections.Be safe and call for assistance.
Sep 29, 2006 | RCA F27667 27" TV
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
RCA 27" TV
typical problem with an older set. sounds like the crts starting to fade as manufactureres Im thinking build into a set faults that they know will happen after a certain time frame and most do this is why there are so many reoccouring falures in a tv sets life. this is simply my thoughts on this subject!! You could have your local tv guy shoot the tube (not with a gun!!) with a crt rejuvenator to maybe clean off the grids of the tube. sometimes this will help BUT its a risk also Sometimes it will ruin the picture tube also. I have a set that I rejuvenated the tube 4 years ago as it looked like crap but to this date s its stil looking good as it did when new!
Apr 01, 2006 | RCA F27645 27" TV
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
Electro Med Services...
