Question about Toshiba SD C2612 (SD-C2612) Internal DVD Drive
DVD not working
The DVD will not play any DVD. When I go to the devise manager, there is an explaination mark, stating the computer cannot read the device driver. I tried to uninstall, and then reinstall the DVD (toshiba sd c2612). The computer automatically recognized the DVD, and stated it was installed; however, I still have the same problem. Any suggestions?
    Problem Solver:
  • 8 Answers
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Posted on Sep 17, 2008
  • jabnet3 Mar 24, 2011
    had searched the Internet for the correct solution for my DVD-cd finally found it with this particular one.....many many thanks....God Bless You....
HP Media Center m7250n will not play DVDs. It plays CDs just fine. It used to play DVDs but has not played them in quite a while.
that seems strange if it reads cd's it should read dvd's
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 22, 2011 | Computers & Internet
My Lenovo 3000 G410 Optiarc DVD/RW AD 7560A can t read just writed cd/dvd. But it dose not happend with the original/licence cd /dvd.
First you need to check your DVD rom drivers if it is detected in the Device manager window, Just click on Start , Control Panel, System then Device manager there you can check the list of all your devices.
  • In Device Manager look for DVD/CD-rom drives click the arrow or plus sign on the left to show he sub Menu.
  • Check to see if there are any Marks such as question marks, Exclamation Points or Red X's.
  • Hopefully there are none of any, if there is try uninstalling the driver then restart the machine it should automatically reinstall the DVD/CD-rom.
  • Now to get the not reading error, Click on Start, then on the Start Search Bar type on REGEDIT then press enter. mvincentc_35.jpg
  • This will open the Registry Editor Window.
  • In the Registry Window follow this key path = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Once the dvd/cd-rom appears a list on the Right pane window will show, on the list looke for upper and lower filters then delete both then close the registry window then restart you computer.
This should help restore you DVD/CCD-rom back to a reading state.
Have a nice day,
mvincentc
Mar 21, 2011 | Sony Optiarc AD-7170S Burner
MY COMPUTER WONT PLAY THE DEVISE
Check the Device Manager in the computer to see if it is listed as well as the driver is installed.
Nov 02, 2010 | Sony Handycam DCR-DVD103 DVD Camcorder
Driver for SONY CDRW/DVD drive seems to be corrupt. Help, anybody
Go to my computer, and right click on it, when the window opens
click on properties, when window opens find devise mgr and click on it.
When devise mgr opens, look for cd/dvd rom drives, click on the little
sign in front of this and it will expand, and you will see the dvd drive.
Right click on the drive and when the window opens click on properties, now at the top you will see a driver tab, click on the driver tab, and it should say microsoft for the driver provider.
The drivers for the rom drives is built into windows,
Now click on the general tab, in the box, does it say this devise is working, or does it say the devise is not working.
You can go back to driver tab, and click on update driver, let it search
the internet for a driver, follow the instructions, it will either say it has the best driver, or it will find one and install it and you have to restart the system,
If the driver is there, and the unit says its working, then it is the drive that is bad, and you might have to buy a new one.
If you get any error codes or if it says anything, you can post back
so we can get this problem fix,if possible.
Feb 14, 2010 | Sony COMBO |CRX850E SLIM % (CRX850E)...
I have a d915 board and i can't find my sound card drivers kindly help me in getting this
You did not state what os system you are running so i'll assume it's Win XP. Go to > Control Panel > Administative Tools > Computer Management > now on left side of window click on Devise Manager...when the list comes up scrool down to Sound, Video and Game Controllers then click on "+" sign to expand and BINGO!...If any sound (audio) devises listed are accompanied with a yellow question mark...you have a problem. Click on the ones with the question mark and choose install driver. Windows will then search for and install your driver.
Jul 28, 2009 | Computers & Internet
Dvd does not work. Light blinks but not seeing it . is there a driver i need or what do i do to fix this
You must determine if the problem is the media you are using (CD, DVD) or the drive itself. (CD/DVD Rom)
First see if the driver is installed for the CD/DVD ROM by Right clicking My Computer and choosing Properties, Hardware, Device Manager. Clikc the plus sign next to DVD/CD Rom Drives to see if there is a yellow exclamation point, or question mark. This means you need to install the correct driver. If there are no yellow exclamation marks or question marks your driver is installed properly.
Next try playing difffernt CD's to see if any of them work. Confirm they are good CD's by playing them on another device, then try them on your Compaq. If the Cd's play on another device you may possibly be experiencing read errors on the CD/DVD Rom drive. Try using a CD Laser Cleaner that will clean the laser head of the CD /DVD Rom. it looks like a CD with small brushes on the music side. This may solve a read error problem. if that does not solve your problem you may need to replace the CD/DVD Rom drive.
Jun 14, 2009 | Compaq Presario Notebook
Cd-rom driver code 10
go to devices in control panel check drivers for cd dvd player if yellow mark on them delete and reload them
Jul 20, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
HL-DT-ST DVD-RW GWA-4082
ya it ll work... first change the cd to write mode ..hence not able to burn files...
Jun 21, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
DVD works but not regular CD ROM
try frimware update for it from site ok pioneer.com ok
Feb 07, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Both drives not recognising disks
Have an LG Super Multi DVD Drive, Model:GSA-4120B.
Won't recognize any disk, CD or DVD and won't play any audio video
Device manager says, it's working properly
Dec 28, 2007 | LG (GDR8164B) Internal DVD Drive
Toshiba SD C2612 (SD-C2612) Internal DVD Drive Logo
384 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
