Question about IBM 4224 Model 101 Matrix Printer
IBM 4224 Printer G111 (172.26.131.26) does not print. Possibly bad card.
Where can I get a manual to show how to do this?
What are you trying to do? Get a Manual.
I have the book I would have to scan it for ya, but what do you need the MIM or the MAP?
Is there a Error Code?
Posted on Jan 25, 2009
  • jfostertech Apr 01, 2011
    I need the manual do you still happen to have it
My printer will not power on what can I do?
If you can open it : Test the power switch and the power unit and change if one dont work If you cant open it: Change your printer
Oct 18, 2012 | IBM POWER SUPPLY 4224 Printer Part 17F4711...
What is a 19 error code on the Ibm printer 4224
Attachment Card Failed Power on Tests.
1. Switch Power off (O).
2. Wait 20 seconds and switch power on(I).
3. If the printer displays (19) again then call for service.
May 14, 2012 | IBM 4224 Model 101 Matrix Printer
How do you reset the 2390 back to the factory default ?
www.lexmark.com/publications/pdfs/form2400/en/enUser.pdf
Shows you how in above manual.
. Turn off printer 2. Move print-head all the way to the left, so it's hitting the left hand wall of the printer. 3. Hold down Alt and Setup while turning printer on. Keep pressed down until you hear the beep and the printhead moves. This can take 5-10 seconds. Hold in the keys and make sure the printhead is over to the left when you do.Note: The printer defaults to IBM mode, this is fine in MEDENT except for letters and prescriptions. If you do factory default and they don't print MEDENT letters or prescription then make sure MEDENT printer setup for type 11 (IBM mode). If they do letters or prescription, then change the printer setup to Epson mode See Also: Switch Emulation Mode from IBM to Epson
Apr 09, 2010 | IBM 2491 Dot Matrix Printer
I need a schematic for IBM 17f4711 power supply made in the 1980's by Zenith.
Sorry - no manufacturer supplies that. You may be better off in using a new supply - many are backwards compatible to the early versions. The basic difference will be the connector style, but the wire colors are the same. Also, the newer supplies have a power on/off input (typically a green wire) that should be tied to ground (common) to turn the power supply on.
Feb 01, 2010 | IBM LENOVO POWER SUPPLY 4224 Printer Part...
Code 56 error
You have a Head Error-Head Drive/Emitter Failure.
Your going to need to check your head drive belt, being that the printer is so old the belts go bad and start to crack and turn into a tar sub. Also make sure to clean your rails, over time they build up dirt and oil and need to be cleaned off.
Rory
rcarndeas@mrp.to
Oct 29, 2009 | IBM 4224 Model 101 Matrix Printer
What is the maximun amount of memory i can install into the IBM 1532 Printers?
The manual shows a SINGLE memory card slot.
The largest memory card I found offeered for the printer seems to be a 512Mb module.
The printers were delivered with only up to a 128Mb module.
Oct 06, 2009 | IBM Infoprint 1532 Laser Printer
I HAVE A 4224 PRINTER FOR SALE. WHO COULD I CONTACT?
Are you looking to upgrade? I can take yours as an exchange or if you are interested i can repair the one that you have like new.
Please let me know. I carry parts and printers in stock refurbished with a 30/day warranty.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
rcardenas@mrp.to
Jun 22, 2009 | IBM 4224 Model 101 Matrix Printer
Error 01
Error 01 is End of Form, Make sure u have paper installed.
The sensor that is at the bottom left that you feed paper thru is were this error is generated. Make sure it is aligned and working.
Also clean with wet paper towel slide in and out
You can also run a Test 851. to see if the sensor is open(1) and closed(0). also check the connection on the board to see if it still connected.
I can go into level 2 support if more help is needed.
Jan 12, 2009 | IBM 4224 Model 101 Matrix Printer
I need hep for my printer
How to get a manual to show how to do this?
Jan 09, 2008 | IBM 4224 Model 101 Matrix Printer
IBM 4224 Shuts off after warm up
4224 were notorious for poor connections between the control cards and the motherboard. Opening the printer and reseating all the cards solves a multitude of problems. Try it.
Aido
Dec 11, 2007 | IBM 4224 Model 101 Matrix Printer
IBM 4224 Model 101 Matrix Printer Logo
358 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
