Question about Miele Washing Machines
Moved our miele washer to our new laundry room and now will not turn on, there is power to the machine. We moved it with care.
  • Anonymous Sep 05, 2008
    I have replace the fuse and plug and check the power still not working. Any ideas?
  • 639 Answers
Dear sarnt,
ngfam at you service!
Balance weight could be out of position! Like in the neptune!
When you get an error its best to call service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
Miele 500 wont let powder release from draw and no water gets in to wash clothes so machine continues on washing
Fixing A Miele Washing Machine- Do It Yourself - YouTube
? 8:48
https://www.youtube.com/watch?v=lSkMUxXja24
Feb 25, 2014 - Uploaded by techtecher
Save money by fixing the Miele washer yourself. Easy to fix. DIY. ... My machine is flooding the kitchen when it starts into thedrain cycle I think..
[PDF]Operating and Installation Instructions Washer W 4842 - Miele
www.mieleusa.com/manuals_pdf/Residential/Washers/W4842_us.pdf
Instructions. Washer. W 4842. To prevent accidents and machine damage, read these instructions before .... Adding/removing laundry during a wash program .
Jan 25, 2016 | Miele Washing Machines
Can I wire my Miele W1918 washing Machine to work on 120 . And if not can you walk me through wire set up.
if the machine is 240 volt system and the mains voltage is 110 volts you can use a step up transformer
Dec 25, 2014 | Miele Washing Machines
My LGfront end loader washing machine is shaking so bad it actually walks across the laundry room 3 -4 feet
I had the same problem when my LG WD-8074FHB was new. LG recalled them and put a larger weight in them. The weight is a hollow piece of plastic filled with concrete in the top of the machine under the cover. It stopped it moving around the laundry.
Mar 04, 2014 | LG WM1814CW Front Load Washer
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
LG front loading washer: recently moved to a new house and laundry room is on the 2nd floor. Re-installed the shipping bolts in the back of the washer that secures the drum prior to moving the washer. But...
Make sure machine is level and all four leveling legs are solidly touching floor at the same time. Make sure leveling leg locking nuts are screwed up to lock legs in place. Check floor for firmness. (try bouncing up and down in front of washer to see if the floor has excessive give.) You may need to re-inforce floor. Wash larger loads. On bulky items, use a lower spin speed. You can re-spin at a higher speed after cycle is complete if you want them spun out better. (some models have a pump and spin only setting, on others, just turn on the power and then only touch the spin speed button to select a 14 minute pump and spin only cycle, then touch the start button.) The only other thing is that the new LG washers use a balance ring now, which makes the machine perform much smoother. (I know because I gave my old LG to my son and replaced it with the newer model, which now runs much quieter, in the exact same location as the old one.)
Jan 13, 2010 | Washing Machines
We moved our whirlpool duet washing machine to do some work in our laundry room. we moved it back and put a load in and it's making a loud humming noise during the cycle. what could be wrong. we turned it...
You may have dislodged the suspended innards from shock mounts that keeps some nose from escaping. I would remove the back panel and inspect the insides to see if one or more corners of the suspended assembly are now out of place.
Nov 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We moved the washer to a different room. When we
Was the place where it was the original laundry room. If so outlet was probably a dedicated line not hook to any other outlets. Now you moved and plugged into outlet that is not dedicated other items are probably being used on same circuit or breaker is to small, should be 20amp.
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer door opens with hinges on the left
Don't you think it would really boost sales if you did make a washer that the front loader door could open left to right . For homes that have very limited laundry room. and no way to switch.
Dec 28, 2008 | LG WM-2277HW Front Load Washer
Washer shakes and rattles when using regular cycle.
just a long shot but open it up and grab the edge of the tub and give it a good tug and a shake in an effort to get the tub (empty) to settle in properly on the suspension springs inside.
Dec 08, 2008 | Hotpoint Washing Machines
Washing Machines Logo
107 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
