Question about HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printing Problem!
My printer has not been printing correctly lately... on one side it makes skipping, mirroring marks . For example, when printing a birthday card, the bottom logo is creatacard. Well my printer repeatedly prints it. It prints it dark in the original spot and then prints it again lighter and lighter next to it. It feels very rough too, almost like its munching it!!!! Help!
  • Anonymous Aug 31, 2008
    printing fullpage spot
  • belalmoha Oct 15, 2008
    My printer Prints colors outside the framework when printing and paper test the printer found that the color black in the place, but other colors no.
     helped me completely out of context
  • 138 Answers
Franko21:
It sounds like you are having an issue with your fusing assembly. Here's the check you need. Measure the distance from the original print on the page and the exact spot where the repeat ghosting (same spot) appears on the page again. Here's the distances that identify the part having an issue. My guess and experience with this printer says it's probably fuser. Seen a lot of 2600n printers with image ghost problems and almost all are fuser related.
2.22" or 56.6mm = Fuser Upper Film
2.47" or 62.8mm = Fuser Lower Roller (Usually Backside)
2.97" or 75.4mm = Toner Cartridge - Drum (Usually One Color)
0.97" or 24.7mm = Toner Cartridge - Developer Roller
1.05" or 26.7mm = Toner Cartridge - Primary Charge Roller
2.15" or 54.5mm = ETB - Transfer Belt (Big Belt on Door)
If it should be the Fuser or Transfer Belt, consider not replacing the part as the minimum cost for either (part only) is $105.00 before shipping. The better alternative is to jump on Ebay and buy a HP refurb or new machine MINUS the supplies. They come with the Transfer belt and fuser. They are cheaper for the full machine than the replacement part. They average about $65.00 thru $90.00 landed.
Hope that helps you. If so, hit me with a FIXYA.
Posted on Sep 03, 2008
  • 3 Answers
U r printer has formed a dust be cleaned and in toners drum has been weak make a new one
Posted on Aug 26, 2008
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
Can't print in SAP R3 to HP LJ2600n
Supported HP Printer: HP Color LaserJet 2600n printer
(Host-Based)
Recommended PCL5 Device Type: SAPWIN
- requires Server-based printing via SAPSprint or Frontend Printing via SAPgui
Supported SAP Release: See SAP Note # 8928
Dec 11, 2009 | HP Color LaserJet 2600n Printer
Color printing (not black)is light on left side with HP color laserjet 2600n.
you have to clean the scanner mirror . open the front cover and remove all the cartridge. you can see a 4 no's of rectangle box in which inside you can a mirrors.clean all the four mirrors.
Oct 20, 2009 | HP Color LaserJet 2600n Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Color LaserJet 2600n Some of the colors are not printing.
replace color cartriges restart and let computer clean the heads
Jul 29, 2009 | HP Color LaserJet 2600n Printer
Double printing, especially down the left hand side of page
replace fuser,if still happening replace transfer belt
Apr 30, 2009 | HP Color LaserJet 2600n Printer
Faded print out even after putting a new toner
Clean All Mirrors Inside the Laser box.(except the 2 motorized mirror)take extra care in cleaning.make sure you dont leave any finger print marks,because it will create another problem..
Feb 28, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 megnta not printing
thanks alot u solutions.iam very happy for giving me this knowledge.faisal
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Printing in color with my HP 2500 all-in-one printer
If the printer is old, then maybe there's dust on the mirrors that the laser bounces off of. See my step-by-step instructions on how to clean it on my website.
Feb 18, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Print Queue failure
Sounds like low toner to me. If the printer is connected by USB or parallel cable to one computer, go to that one. Click start-programs-HewlettPackard-HPlaserjet utility. The utility should let you see how much of each toner color remains.
Aug 15, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
589 people viewed this question
Seeker5211
Seeker5211
