Question about IBM ThinkPad R40 2722 Notebook
Ibm thinkpad r40
When i push power, there is no visual or audible effect on the laptop. no lights nothing, so i do not know what it could be, is it possible to be the motherboard.
laurence
i am having the some problem the battery ran down to less than 2% and now my computer will not turn on. No light when you press the power button, I have re seated the memory. Reseated the HD. Changed AC adapters and still nothing. Please help. Was working until battery ran low.
    Genius:
  • 2,028 Answers
This could be a problem with the battery, try removing the battery and starting on the adapter only. If this doesn't work, then I'm afraid it is going to be a motherboard problem, most likely with the power management system, this is the most common area with this type of problem. You can take it in for diagnostics, but I'm afraid you're going to end up having to replace the motherboard in order to fix the problem.
Posted on Aug 26, 2008
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 No PowerUp
If the the ram is the problem of your system, there should be a power on light on the system. indicating that some of the component of the system is not working correctly. But since you mentioned there is no light, it is the possibility that the problem is the motherboard itself.
Feb 26, 2009 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 Intel Centrino Upgrade to Intel Core 2 Duo?
According to system specs your system is not compatible with the Core 2 Duo or Centrino Core 2 Duo. To upgrade to those chips you would need to replace the motherboard with one capable of running those chips. If you decided to do that you would almost surely need new RAM as newer boards use newer technology. By the time you did this the upgrade would not be cost effective. Hope this helps & please remember to rate my answer. Thanks.
Feb 03, 2009 | IBM ThinkPad R40 2722 Notebook
IBM R40 hardware malfunction
press F1 on boot up and get into the bios, reset defaults and then chane the boot order to the CD/ROM, save changes, reboot and you should be able to install XP
hope this works
kind regards
Nov 18, 2008 | IBM ThinkPad R40 2897 Notebook
WHAT ARE THE DRIVERS NEEDED IF I WANT TO FORMAT MY IBM ThinkPad R40 2722 PC Notebook?
is the windows cd for ibm specifically?
if not then you will need:
a sound card driver (optional)
a graphics card driver (optional)
a cd rom driver (maybe)
drivers for usb ports (optional)
and any other drives/ input devices on your laptop will need drivers.
when formatting bear this in mind. All data will be lost! proceed knowingly and with caution. one mess up will land you in problems up to your shoulders!
i recommend finding out how to do it safely
Nov 07, 2008 | IBM ThinkPad R40 2722 Notebook
you can buy ext. hd case to back up your things, if your ibm can't boot then might be your motherboard got problem or graphic card.
Sep 08, 2008 | IBM ThinkPad R40 2897 Notebook
Ibm thinkpad r40
Completely dead could be the power supply, if not, then the board.
Jun 06, 2008 | IBM ThinkPad R40 2722 Notebook
Ibm thinkpad r40
I need the instruction on how to install a replacement DVD/CD player on my IBM R40 thinkpad Laptop.
Thanks,
Moses
Feb 22, 2008 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
Can't boot my Thinkpad R40
its ok pat sounds like mobo power ships not doing thers jobs nomore ok would have to buy new motherbord ok thx nick
Feb 06, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 2722 Notebook Logo
83 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
