Question about Goodman CKL60AR60 Air Conditioner
HELP!!! Help wiring new motor for CKL60-1
Hi - Per your recommendation, a new condensor fan motor was purchased. It's an AO Smith - FSE1026SV1 (Replacing an AOSmith F48F97A86) they also provided a new capacitor - small 2 post about the size of 2 C-cell batteries.
Everything is exactly the same except amps on new motor was 1.8 vs old at 1.5. Everywhere I looked showed this as a good replacement.
I wired it up and it ran fine for several minutes and then shut off. (the old one was replaced becuase it would run about 60-90 minutes and then stop - concensus seemed to be bearings....
I am hoping I just have something wired wrong. There are two capacitors,, one is just smaller than soda can and has 3 terminal - marked herm, fan and blank. The smaller is the one that was replaced, it has two terminals and neither was marked.
Old wiring Fan had Black, Brown, and Purple.
Yellow compressor wire on "HERM" terminal, was also jumpered to the fan capacitor. (call this term 1).
There is a red wire from the contactor to the unmarked terminal on the larger cap.
The purple wire was connected to term 1 on the smaller capacitor and the brown wire was connected to the second terminal (term 2) on the smaller capacitor.
New wiring - Fan has Black, Yellow, Brown and Brown/White.
The Large capacitor and Jumper to Term1 stayed the same
Yellow Fan (replaced purple) went to Term 1 on small capacitor
Brown went to Term 1 on small capacitor
Brown/White went to Term 2 on small capacitor.
    Champion:
  • 254 Answers
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Posted on Aug 28, 2008
A.O. Smith c48k2pa105c5 pool pump motor was running fine for 3 weeks. The other day it shut off cause of the thermal switch. Well now when I turn it on it works fien for a couple minutes then it shuts off...
If you mean that this motor is only 3 weeks old, and this is happening, return the motor.
If its an old motor and this is happening, purchase a new one. Even if you had a technician come out to look at the motor, chances are it would cost more than the motor itself.
Largest causes of thermal overload are.
-incorrect wiring
-wiring to wrong voltage
-incorrect wiring size
-bad motor windings
-bad rear end bearings.
Apr 27, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Unsure of capacitor terminations for ao smith condensing fan moto
Does the motor data plate say anything about the motor. You can hook up a motor like yours with 3 wires. First use an ohmmeter and check the resistance between the brown/white wire to the black then the yellow wire. The resistance between brown/white and one of the others should be pretty much 0 ohms. If not check between the brown wire and the black and the yellow. Which ever wire has 0 ohms with the brown/white wire is the common leg. You can put a wire nut on the brown/white, it will not be used. Next the brown should be for the start winding and the other wire left over will be the run winding. Then connect the common to L2. L1 will go to the run winding and one side of the capacitor and brown will go to the other side of the capacitor. I hope this isn't too confusing. Let me know if I need to explain it better.
Jun 09, 2010 | Heating & Cooling
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Jul 12, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Goodman CKL60AR60 Air Conditioner Logo
2,611 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
