Question about AOpen 1849L (96 NKU01 G02) PC Notebook
Blank screen Hi Computer Expert, i have a Laptop (1845-L 15" SXGA + B/U) here with me to which its experiancing blank monitor (no graphics output on the monitor), could you help me out in posiblities in recovering.
Check to make sure lcd is not turned off by pressing FN+F3.
Dan
Posted on Sep 14, 2008
Screen is blank. Monitor makes rattling noise.
Hi There, It sounds like your monitor is faulty.
Connect your monitor to a laptop, and try to see if you get picture that way.
Go to Graphic Properties and select Clone screen.
you should see the same projection on the laptop screen as the monitor.
Let me know the results.
Dec 18, 2012 | Samsung SyncMaster 930BF 19" LCD Monitor
Hi, my hp compaq nc6220 switches on but the screen wont light up
Hook a external monitor to the video output on the back of the laptop, if monitor works, it means that the laptop screen has a bad inverter board or back light issue. If the monitor has a blank screen like the laptop, the video graphics card is bad, or you have motherboard problems, suggest a computer tech.
Jan 05, 2011 | HP Compaq nc6220 Notebook
Dell M2300 issues: After several times of a freezed screen & rebooted the computer while either on the internet or working with "Autocad Inventor", it's finally gave up on me, on the last...
Isolate where the problem is: it could be the LCD display or the graphics circuit on the main board. Connect the VGA output of the laptop to an external monitor - one that you know is good. From the function keys, activate the VGA output of the laptop - it's suppose to switch between the LCD display or to the external monitor. Switch it to the external monitor. If the external monitor works, then you have a problem with the LCD display of the laptop.
Dec 22, 2010 | Dell Precision M2300 Computer Workstation ...
No output from graphic card
The video output on many portable computers toggles off and on with one of the function keys. Look for a function key with the image of a monitor on it, then hold down the Alt key and push the function key once or twice. It usually has several choices that you rotate through - computer monitor only, video out only (your screen goes blank) and both screen and video out.
Sep 13, 2009 | Sony VAIO NS Series VGN-NS110E/L NoteBook...
No video output from my computer.
Are you using an ON-board graphics adapter or a separate VIDEO CARD? Some motherboards lets you set the video output to "DISABLE ONBOARD GRAPHICS" if you have installed a video card (BIOS). You may have plugged the monitor cable to the onboard D-sub connection instead of using the Video Card D-sub connector.
Normally a flashing green power light means the input it receives from the video output is too much. You may have set the resolution too high or the bit depth too high. Consult the monitor manual on the rates it can handle. To be safe, try starting the computer on safe mode just to check if it is indeed the problem. If it boots properly and you can see your desktop, then there's a chance that the setting was too much for the monitor to handle.
Hope this gives you an idea.
Mar 15, 2009 | SAMTRON 94B 19 inch LCD Monitor
Blank screen
Hi!
A simple test is to connect another working monitor, to figure out if the problem is at cable connection or at graphics card 's output, and replace properly.
good luck!
Dec 26, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
My toshiba laptop blank screen
hi try using ur vga port to output to a moniter if this works ur inverter is knackered if not maybe screen graphics or inverter.
Sep 06, 2008 | Computers & Internet
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Laptop screen is blank
There could be a screen fault or the connection to the motherboard is damaged, but try the driver first to see if it is corrupt. Go to My computer>right click>properties>hardware tab>device manager, then look down the list for graphics adapter, click on the '+' sign and right click on your controller and select uninstal. Re boot your pc and hopefully your screen is working again, if not it is more serious and needs expert referal.
Apr 23, 2007 | Compaq Presario 900US Notebook
AOpen 1849L (96 NKU01 G02) PC Notebook Logo
91 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
