Question about Danby Portable Air Conditioner
Danby DPAC120068 The manual says that the external bucket is only supposed to fill up when you make use of the dehumidifying mode. I bought this thing in mid-June and ran it every day for a month with no problems (air conditioning mode). I then stopped using it for 3 weeks (unplugged it from the wall) because we had a family emergency in California. Within 4 hours of powering it on, the bucket filled up and now fills up every 6 to 8 hours no matter what mode I am using. I never had to empty the bucket with AC mode before. Calls to Danby went unanswered, as did my e-mails. The store I bought it from said that if the item is under warranty that I need to contact Danby, again pointless because they fail to respond. Plus I bought an extended warranty so I'm guessing that I am completely out of luck here.
  • 3 Answers
I recently encountered the same issue. First off, with the external tank installed is there an icon on the display panel indicating the tank is installed?
No? Then the two sensors are not picking up the magnets in the the "arms" on the back of the tank. It's a poor design for sure, on my unit the tank does not sit flush enough to the back of the AC, if I held the tank firmly to the back the icon would come on. I just used a bit of cardboard at the bottom of the support tray to press the tank firmly to the back of the AC.
Theory is as the external tank fills up, water will run into the "arms" and raise the magnets tripping the switch which tells the unit it needs emptying. But the magnets in the arms are not strong enough if they are not close enough to the sensors. So my cardboard solution lasted only one tank.
I ended up getting some flat neodymium magnets (that I scavenged out of a hard drive), and taped to the sensor that had the gap. I wouldn't recommend doing this to both sensors since it would eventually overfill, only one sensor needs to "trip" for the compressor to turn off.
If you answered yes to the first question (the bucket icon is there), then it's most likely the pump not working on the internal reservoir, or something related to that. Can't help you there...
Posted on Aug 21, 2009
THERE IS AN INTERNAL BUCKET ASWELL.... MAKE SURE YOU DRAIN IT. DRAIN IT BY UNSCREWING THE DRAIN PLUGS ON THE BOTTOM.... UNPLUG FIRST :)
Posted on Jul 31, 2009
  • 21 Answers
My guess is that the July weather was more humid than June, and the unit was not able to evaporate all of the water it collected.
Also, your room must be very humid if you are extracting enough to fill that large tank.
Re customer service: That's too bad. Why bother with an extended warranty if the store tells you to eff off??
Posted on Jun 18, 2009
Danby Dehumidifier DDR7009REE leaking water, bucket not full
The unit may need cleaning. You can contact Danby customer service (1-800-263-2629) to get in contact with a technician.
There may be something clogging the passage to the bucket and the water is finding the path of least resistance.
As well, it is important to remember to clean the filter once a month.
May 14, 2012 | Danby DDR5009EE Dehumidifier
I have moved my Danby DPAC120068 Designer Air Conditioner to my basement to use it as a dehumidifier. What do I need to do? Do I vent the unit still?
No matter were you place it, it must be vented just like before. Which may be difficult in a basement, depending on how high off the floor the window(s) may be. As a basement dehumidifier, don't expect much. As, an AC/Dehumidifier it only has a 4 pint per hour capacity and then will have to be drained.
Hope this helped you and hanks for choosing FixYa.
Sep 10, 2011 | Danby DPAC120068 Air Conditioner
I just purchased a used portable air conditioner, a danby dpac120068. It is not producing any water when in dehumidify mode. Also, it seems as though the air conditioner is on even when in dehumidify...
The A/C will be on when dehumidifying... that's how it does that...
If it is not collecting water, it is probably because the humidity is too low in the house already...
I would give it more time....
heatman101
May 25, 2011 | Vacuums
Danby ddr7009ree - continuous drain won't work
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
Aug 31, 2009 | Danby DDR6588EE Dehumidifier
Deshumidifier problem
The manufacturer suggests, even though state not required, to leave
required ac termination kit in place even in dehumification mode.
This should reduce your energy conflict.
Aug 04, 2009 | Danby DPAC120068 Air Conditioner
Red light is on???
You need to empty the water in the tanks, there are two one is external the other is internal if you do not have the external tank attached do so and with the unit of, then turn the unit on and put it in cool mode and watch for the water to drain if this does not work emty the water from the scre holes with the unit unplugged and drain it outside you will need leverage as it will need a slight tilt to do so. Hope that helps..
Jul 31, 2009 | Danby DPAC120068 Air Conditioner
Red light comes on for no reason. Danby DDR6588EE dehumidifier
I have a DDR4588EE (same model with 45 pint capacity) and had the exact same problem. It's caused by the float at the top of the bucket being in poor contact with the "full" detector button. When the bucket is not full, the float on the bucket is supposed to press against the button. When the bucket fills, the float is supposed to push up off the button which causes the unit to stop and the red light comes on. The problem is that for some reason, the float isn't pressing hard enough against the button to push it properly in when the bucket isn't full. I fixed it by sticking a few little squares of duct tape (3 or 4 layers) on the float to make it press the button more firmly. Seems to be working fine now. Careful not to put too much tape or it might press too firmly which would result in the float not releasing the button when the bucket is full, and water will spill over.
Sep 17, 2008 | Dehumidifiers
Trouble setting up the Danby DPAC120068
Hi, you have to put the support for the tank under and it will lock
Jun 08, 2008 | Danby Portable Air Conditioner
Danby Portable Air Conditioner Logo
799 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
