Question about HP Computers & Internet
My memory stick will not show me the pictures when I put in in the Digital media slot,it worked the other day with a Sony memory stick from my Sony Camera, and then a neighbor wanted to see her pictures and her memory stick was from a Cannon camera different size but it worked ,and now either will work
  • brynee Aug 25, 2008
    The problem was not solved.
    How can I reset my Digital Media slot.
    So that my sticks will work?
    Genius:
  • 3,422 Answers
If the stick is not working on the both the camera then reseting your camera will not fix the issue.You will have to format your card but you will loose all your pics.IF you have a card reader in your laptop insert the card in it and backup all the pics and reformat the card.
If you need anymore help then let me know befroe you rrate the solution.
Posted on Aug 25, 2008
  • HP Master
  • 13,433 Answers
Do you have a reader on your pc where you can stick the memory?
see if it works there.
if not, reset your camera. You can format the card in the camera or in the computer. whats the error you get or what happens?
use the add a comment instead of requesting another expert. thanks,
Ekse
  • 4,472 Answers
Ok what is the model of this digital media slot or the unit the slot is in. More information is needed to assist you properly.
Thanks,
Lee
  • Lee A.
    Lee A. Aug 26, 2008
    As i had already previously mentioned more information is needed to properly assist you.
    Thanks,
    Lee
    Master:
  • 521 Answers
Ret the unit .by removing the batterys.and keeping it in OFF mode for some time and then ON it.it will work. thanks
  • tech expert12 Aug 25, 2008
    i mean reset the unit.
    Select all the files and folders that you want to transfer to the memory stick. Then press Ctrl+C (or copy), then go into My Computer. Go into the memory stick folder, then press ctrl+v (or paste)
    Also some advice with ME and flash drives - always use the REMOVE HARDWARE SAFELY function - it isn't like XP where you can just take it out! If you don't you risk losing all data and corrupting the flash disk.
    it depends upon the system you use.thanks.please rate the solution.
Where do i install the camera memory card into my laptop
According to the manufacture web site that model has a - • 4-in-1 Bridge Media Adapter,with Secure Digital, Secure Digital High Capacity, Memory Stick™, Memory Stick PRO™, Multi Media Card™ [shared slots]
So basically you need to look for just one slot, and you have to use one of those memory formats, If your using something else then it wouldn't work, You'll need a USB adapter that will read your type of media, The slot looks like its on the front edge of the laptop. It'll be a pretty small slot across the front, about where your left thumb would be. Its possible you have a model that didnt have one. The Bridge Media Adapter slot (available on certain models) supports the use of Memory Stick,, Memory Stick™ PRO, Secure Digital™ (SD™), MMC™ (MultiMediaCard™), or xD-Picture Card™ media. These media can be used with a variety of digital products: digital music players, cellular phones, PDAs, digital cameras, digital video camcorders, etc.
Lots of good info and owners manual at. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2221250&rpn=PSLB8U&modelFilter=L300-ST3502&selCategory=2756709&selFamily=1073768663
hopefully you can just click on all that,,,,,,
Feb 12, 2011 | Toshiba Satellite Pro L300 Notebook
Sony digital still camera dsc-s30 is not show pictures in my pc
I'm sorry you're experiencing difficulty with transferring images from the Camera to the Computer. I have provided a link you can view the steps to transfer images:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C170591
The Camera may not be compatible with newer Operating Systems. In that case, you can remove the Memory Stick from the Camera and insert in to the Memory Stick slot on the Computer to transfer the images.
If your computer does not have the memory stick slot, you may purchase one as it does not cost much..
Thanks for understanding.
Jan 22, 2011 | Sony Cyber-Shot DSC-S30 Digital Camera
The camera just says reinsert memory stick. Is there any way to get my pictures off the memory card?
Yes you can load your memory stick to any laptop and get it downloaded. Most of the present day has a memory slot and you will be able to retrieve the data from the memory stick. If the slot does not accept then use an adapter. I hope you can try this out with the help of any friend who has one such device. Hope this helps. Good day
Jul 13, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
Sony dsc-f717 memory stick error I have a problem with my camera mentioned above, error number is C:32:01 that shows after I take several pictures or a short video. I changed the memory card into a new one...
A letter and number error code of C:13:xx is an indication the recording media (floppy disk or Memory Stick® media) you are using is either not supported for use with the camera, not formatted properly, or is damaged or faulty. Since you have swapped out the memory already and reformatted it, we'll probably have to assume that the reader is dirty. But first make sure that you re-formatted the stick using the camera, not a computer, as Sony claims that a computer format is not supported.
CLEANING THE READER
Blow into the stick slot with a can of compressed air, using a q-tip. If it still doesn't work you may need to buy a commercial memory card slot cleaner.
May 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
My sandisk memory stick pro duo wont work anymore
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Sep 11, 2009 | Sony Cyber-Shot DSC-P92 Digital Camera
How does the media card reader work on the side of the hp pavilion dv4. It is supposed to allow for a ms/pro but it just kind of falls in. It almost looks like an adapter is supposed to fit in the slot
The Digital Media Slot supports the following digital card formats:
● Memory Stick (MS)
● Memory Stick Pro (MSP)
● MultiMediaCard (MMC)
● Secure Digital Input/Output (SD I/O)
● Secure Digital (SD) Memory Card
● xD-Picture Card (XD)
● xD-Picture Card (XD) Type H
● xD-Picture Card (XD) Type M
Here's how to use the memory card reader:
Jul 14, 2009 | HP Pavilion dv4-1140go Laptop
Memory Stick error c:13:01 My old 512 MB memory stick is working fine. However, recently I brought a 2 GB memory stick and when I put it inside, the camera (Sony DSC S40 cyber shot) shows: MEMORY STICK...
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Nov 30, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber Shot DSC-H9
The camera may display a MEMORY STICK ERROR or C:13:xx message (xx can be any random number) on the LCD screen for the following reasons:
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Remove and re-insert the Memory Stick® media several times.
  2. The inserted Memory Stick media is not compatible with the camera. Check your instruction manual for information regarding Memory Stick media compatibility.
  3. The inserted Memory Stick media is not formatted. Format the Memory Stick media using the FORMAT option in the camera menu. WARNING: There is a risk of data loss. Formatting will erase all stored data, images, movies, etc., from the Memory Stick media.
  4. The terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
  5. The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
Thanks
Proton
Oct 02, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Pictures only save to internal memory, not memory stick...
DSC-W80 sybershot camera has facility when you insert Memory Stick in its slot, it automaticaly selects this memory card and starts saving data on it and internal memory got suspended.
Pls check memory stick 2GB and inert it correctly in memory slot in camera.
Aug 14, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Memory stick duo not showing pictures
It may be that you actually have the pictures stored on the camera's onboard memory and you may have to plug the camera in directly to access the pictures. Or Sony may have a strange way of accessing the files on the device (they have done the same with their MP3 players), so you may be limited to using their software to get the pictures off the camera (or memory stick).
Sep 06, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
