Question about Logitech Harmony One Advanced Universal Remote with Color Touch Screen
Best setting in miliseconds to turn on the panasonic pt ax 100 projector?
Whenever I try to set my new remote control (Harmony One) to watch tv (projector), sometimes the projector doesn't turn on. Does anybody now which is the best setting (in miliseconds) to have the right singal send to the projector?
  • 2,237 Answers
You need the manual.
Posted on Aug 19, 2009
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Why red light is on ?
Its the most common poblem with the ax 100-200 projector.Many a times only the ballast requires to be replaced.yet on may occasions both mainboard and ballast requires replacement. its best to confirm with a good known working ax200 and replace first the lamp, ballast and the mainboard.panasonic ax 200 lamps also have failed premature as per my experience.
May 04, 2014 | Panasonic PT-AX200U Projector
Remote control
Harmony makes a really good universal remote that plugs into your computer. You enter the make/model # of your equipment and all (or most) of the equipments features are available on the remote. I use 1 remote for 7 components and it has an activity button that when pressed will turn on all components associated with that activity IE "Watch DVD" will turn on DVD player, T.V. and set it to proper channel or input and turn on the stereo and set it to the proper output.
Jan 13, 2012 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic pt-lc56u projector but need a remote for it. any ideas ? its a very old model but truly a great machine
You can go on logitech.com navigate to the remotes where you can see if they support your projector. Then you get one of their harmony remotes.
Mar 25, 2011 | Panasonic PT-LC56U/76U Remote Control
My projector pt-lb10e cannot start up, the standby light is on but when try to press the on button nothing works. How can i reset the projector?
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
Sep 16, 2010 | Panasonic PT-LB10E Multimedia Projector
My remote control has broken.
I would check out the Harmony 510 remote control. It may be a little pricey but it is the best universal remote on the market for the money. It also allows you to control your DVD unit as well as your TV without the requirement of selecting which one. Harmony remotes are activity based in the you pick what you want to do such as “Watch TV”, “Watch DVD” , “Watch VCR” etc.. Then It turns the appropriate units on and then sets them to the correct input. Makes it real easy once set up. Another advantage is the IR codes are stored on line and constantly updated so new products and codes can be added.
Check it out:
http://www.amazon.com/Logitech-Harmony-Advanced-Universal-Control/dp/B001F51G1Q/ref=sr_1_10?ie=UTF8&s=electronics&qid=1270172488&sr=8-10
Apr 02, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Pc to projector fuzzy as hell, all diff resos.
Well the ax-100 can only display 1280x720. If you output anything different - lower or higher - the image needs to be rescaled, which inevitably makes it a bit fuzzy.
May 29, 2009 | Panasonic PT-AX100U-EC DLP Projector
Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
Hi Mac
Yes you can just take out the old lamp and install the new one in your existing lamp bracket. Simply unscrew , replace and screw back in.
Apr 12, 2008 | Panasonic (ET-LA995) Projector Lamp for...
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
342 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
