Question about SanDisk Sansa e260 MP3 Player
Sansa mp3 e260
New to the mp3 technology- after making a playlist, how do I download ONLY the playlist to my mp3- when I try to transfer the songs over in Synch mode, I end up downloading ALL the songs I have on my computer, not just my playlist!
    Problem Solver:
  • 9 Answers
Well, one way of fixing this can be to watch the files sync to your mp3 player and when it starts syncing the unwanted files, just simply press "stop sync". I think i know what you are using and i had the same problem at first. you will make a sync list and click sync but after that list if finished, it will sync the rest of the songs from your computer also, you can just wait for your wanted sync list to be finished and as soon as it begins to sync the unwanted media, just press stop. this wont harm your computer or your mp3 player.
Posted on Sep 14, 2008
Songs will not transfer to E260
Make sure the songs that you put on are in a format compatible with your player.
If they are not compatible they will not show on the screen or play....
May 06, 2009 | SanDisk Sansa e260 MP3 Player
Download songs from CD
i burn my cds on windows media player, create playlists (which is what u want) and when u plug ur mp3 in u need to syncronize it and it should transfer hope it helps
Dec 02, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Sep 29, 2008 | SanDisk Sansa e260 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Download music to my scandisk sansa e260
When you turn on the player, select the music menu, and then scroll down until the playlists logo appears - select that and then your playlist name should be there.
If it still isn't there, then the songs that you tried to sync have some sort of licensing restriction on them that does not allow them to be synced to a portable device - wmp will show them as synced, but alas - they will never actually show up on the player.
May 22, 2008 | SanDisk Sansa e260 MP3 Player
Shuffle seems to play same songs
The shuffle feature shuffles songs randomly - no way to change the order.
On the Sansa Clip, you have to make the changes to the song order in Windows Media Player first, before you transfer the playlist to the Sansa, using the advanced tag editor function; change the track number. If you have already transferred the song(s) over to the Sansa, you must delete the songs on the Sansa first, or else it will not accept the playlist transfer with the new track order. You can always go back and change the track numbers that are stored in your WMP library after you have transferred the playlist to the Sansa.
-Tha Mp3 Doctor
Jan 25, 2008 | SanDisk Sansa Clip MP3 Player
Mtp mode
uuh no it dosent...nice try tho
Jan 05, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260
When it comes to deleting songs, I went on the program I use to get my music on and clicked on the sansa 260 and found my playlist. I bet if you connect your sansa and look around that program, you could probably find your playlist and start deleting.
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
