Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Repair Kit Did you get the Mits going? How good is manual? Does it help with getting to the boards?
    Problem Solver:
  • 6 Answers
I bought the kit here,
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits/osCsid/145ffde26a9336eaf57c21ff6389def7
It took a lot of patience and a soldering tool I bought at radio shack for $20.00 to be able to remove and add the new capacitors. But the TV is back up and running now, I had to replace two 3300uf 10volts, but replaced them with the ones on the kit which were 3300uf 16volts and like I said the TV is well and running now. Good luck.
Posted on Sep 09, 2008
  • Jasso A Sep 09, 2008
    If you want post your e-mail and I can send you the manual , but if you buy the kit, it already comes with it. That was the best site I found with online assistance and all the things I needed for the fix, Good luck.
  • 927 Answers
Good Day, gestephe;
Can not get boards from Mits. You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 16 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Posted on Aug 30, 2008
Where is the fuse located on my Emerson TV Model lc320em81. The TV wont come on after a pop when I turned it on.
Here is the service manual for your set https://www.manualslib.com/manual/756899/Emerson-Lc320em2f.html
If your know how to solder and have the equipment to do it here is a repair kit that should get it up and going for a few bucks...
https://www.ebay.com/itm/19pc-BA17F1F0102-4-5-EMERSON-TV-LC320EM2-Philips-BA17F8F0102-2-REPAIR-KIT/311759032841?epid=943740765&hash=item4896495209:g:8pEAAOSwp5JWZwTl
Double check to be sure your set has a BA17F8F01 power board, you can order a new replacement board from Shotjimmy as well for a bout $45 ...Good luck!!
Oct 29, 2017 | Emerson Televison & Video
Blinking Green Light of Death on Mits WD 52525
The V26 DM repair kit will usually repair that issue. You can get the kit at www.tvrepairworld.com the kit contains the replacement capacitors and the CD with Instructions.
Nov 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blink green light of death - mits ws55613
Just click below for the solution desame as your problem;
http://www.fixya.com/support/t1012464-fixed_blinking_light_but_still_no
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Mitsubishi WS-65513 65" Rear Projection...
you can get the repair kit which contains the replacement capacitors and the CD which includes detailed photos that show and explain how to do the repair, and the cD even contains the full service manual with full schematics manual as a bonus. Heres the link to the proper DM kit for your model.your model is the V23 chassis.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v23-dm-repair-kit/cName/repair-kits
Jan 24, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mits TV blue Screen
I fortuneatly bought a 4 yr warranty from Best Buy on my Mits. same thing happened with the blue screen fuzzy white diamond. The geek squad techie showed me the 2 capacitors that go bad on the power board and he ordered them and once they were replaced the TV worked perfect again. I have 2 weeks left on the warranty, so i'm calling them today to get my last free bulb(screen is kinda darkening, kinda) hopefully i can convince the technician. This was one warranty that bad for itself.
if you have any electronic skills you can replace these capacitors yourself, once you get into the guts of your unit.
Good Luck
Oct 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mits. 62525 code 34 lamp abnormality
you need more than 2 capacitors there are 8 that need to be changed, You can get the V26 DLP power pwb repair kit at the following link which has the proper capacitors and instruction CD.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mits TV problem
I finally got my TV fixed, I had to replace two capacitors the ones that were bad seem to be the same ones everyone else is having problems with, they were bad when I pulled the board out, they read 3300uf 10v and I bought this kit at this site http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits/osCsid/145ffde26a9336eaf57c21ff6389def7 that came with the replacement ones which were higher voltage but they worked just fine, if you order the kit, it will come with a manual and a bag full of capacitors, but you will probably just need the two I replaced which read 3300uf 16volts. I bought the soldering tool at radio shack for $20.00 it came in a kit as well. that was it, so like I said the TV is well and running now, it's great to finally get to see out of it, good luck!
Sep 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV not turning on
Four bad capacitors in DM module = common repair for a
qualified Mits repairman.....1000mf/25v 105 degree............T.
Jan 18, 2007 | Mitsubishi WS-65713 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
166 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
