Question about HP Pavilion a1410n (ER890AA) PC Desktop
HP Digital Media Archive Pop UP
I getting a repeated a pop up box called Digital Media Archive that states "The feature you are trying to use is on a network resource that is not available. Click OK to try again or enter an alternate path to a folder containing the installation package EZARC.msi in the box below" "An installation package for the product HP Digital Media Archive cannot be found. Try the installation again using a valid copy of the installatio package EZARC.msi" When I click nothing happens and the pop up continue randomly. -I located the HP Archive inn the Add/Remove window and clicked on additional information which shows a source"HP" Clicking on this takes me to home page of Sonics and from there I can't find any reference to HP Digital Media Archive. -I also went to HP Application Recovery and tried to find HP Digital Media Archive to reinstall it, but it is not listed. I'm not on a network and have tried to find EZARC.msi with not luck. HELP! the ordinal 181 could not be found in the dymatic linklibrary PX.dll DMASchedular
  • 349Soldier Sep 17, 2008
    Starting every time i start my PC I'm getting a pop up every 5 min that...Windows is trying to configure "HP Digital Media Archieve" and also "Sonic MyDVD Plus". The feature you are trying to use is on netwrk resource that is unavailable.
Me aparece una ventana dificil de serrar pidiendome el archivo ezarc.msi
Posted on Sep 18, 2008
DigitalMedia Archive window
Here is the resolve, straight from HP Tech Support.
Sometimes, during load, Roxia Digital Media Archive doesn't load correctly, or becomes corrupt. This is where you are getting the EZARC.msi request from. If you follow these steps, you shoud resolve the problem.
start > all programs > HP Application Recovery
When the Application Recovery console comes up, Choose Application Installation then click NEXT.
When the list comes up, highlight Roxio DigitalMedia Archive by clicking on it, then click the "Install" button.
It will re-install Digital Media Archive, and fix your EZARC.msi search issue.
Hope this helps.
Jan 27, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
its been how long that u ahve been facing this problem
Apr 06, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
What you need is a software that uninstall files from the registry, which will remove all lingering dll's etc. I normally use this one.
Your Uninstaller ver2008
http://download.cnet.com/Your-Uninstaller-2008/3000-2096_4-10143715.html
Apr 12, 2009 | HP Pavilion m7560n PC Desktop
The setup file was stored on a network, it wasn't on your computer and now its trying to get it and it can't find it. you will have to get a copy of the file to your computer and then when it asks or the pop up comes you need to direct it to the file you got.
Mar 14, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Reinstall Sonic MyDVD from the Application Recovery. A lot of HP computers have done this or produced that constant pop up.
If that doesn't work, go to:
Start > Run and type in msconfig in the box.
Then click the Startup tab and uncheck the box beside DMA (digital media archive)
Click Apply then Close. Reboot when prompted and you shouldn't get that annoying pop up any longer.
If you don't even use the Sonic MyDvD program on the computer, just uninstall Sonic completely from Add/Remove.
Mar 09, 2009 | HP Pavilion Media Center TV m7680n PC PC...
Sounds like you have may have it run on startup. Just to see you can use msconfig to temporarily disable it by following these steps:
That usually means that a program that starts when Windows starts isnt functioning correctly, You can test it by clixking Start > Run > type Msconfig and press enter. After that click the startup tab. Here you will see programs that load when Windows starts.
If you recognize the program thats causing the issue, simply click the box to the left of the item to uncheck it and click OK. You will then be prompted to restart.
As the machine restarts, check to see if the issue has disappeared.
If so, great. Be aware that you that you will be prompted with a "System Configuration Utility" dialog that lets you know you are using Msconfig. If you don't want to be warned of this, click the box that says "Dont show this message..." and click OK.
If not, run Msconfig again, and uncheck the next suspicious program and repeat the process until the problem disappears.
Below is a link with information on using Msconfig. It also has other links that include information of some of the programs that you might see in the startup window of Msconfig.
http://www.netsquirrel.com/msconfig/msconfig_xp.html
NOTE:
There's is a "Disable all" button under the startup tab. But I wouldn't suggest using that initially. It is better to uncheck them one at a time so you can see what is causing the issue.
Hope this helps. Please remember to rate this information.
Thanks
Aug 08, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Help... 1640n
Here's what HP has to say about your error...It appears to be an issue with Sonic MyDVD. Reinstallation of the program seems to be the solution.
Jul 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
THE FILE IS CORRUPT OR HAS BEEN ERASED THAT'S WHY
-> Click start > all programs > HP Application Recovery
-> When the Application Recovery console comes up, choose Application Installation then click NEXT.
-> When the list comes up, highlight Roxio DigitalMedia Archive by clicking on it, then click the "Install" button.
It should re-install Digital Media Archive, and fix your EZARC.msi search issue or problem.
I HOPE THIS HAD FIXED YOUR PROBLEM... ;)
Jan 10, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
If you are running windows xp, go to start / run . type: msconfig
Go to the start-up tab and see if you can find a reference to the "Digital Media" program and uncheck it.
Also look in the start-up folder in Start / All Programs for this program.
You can delete it from there. This does not remove the program, just does not tell it to start automatically. If you don't use the program, uninstall it.
Sounds like one of those ADD-ON programs that get installed with printers or cameras.
Jan 04, 2008 | HP Vs17 17" LCD Flat Panel Monitor
well guyz... i got a solution... while u get the pop-up... open the task manager... and then search for the process DMASCHEDULAR
and end the process... it worked for me...
Feb 09, 2007 | HP Pavilion a1410n (ER890AA) PC Desktop
HP Pavilion a1410n (ER890AA) PC Desktop Logo
614 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
