Question about Acer AL1716B 17" LCD Monitor
LCD Monitor wount turn on Black screen
The green power button flashes but the screen stays black and wount turn on , is ther a sloution for this
  • 3 more comments
  • Anonymous Aug 31, 2008
    Monitor light is flashing green, screen is black as if it is powered off, and there is a slight buzzing noise in the back of the screen. (noise which I've not heard until now). I've restarted the computer, unplugged the cords etc. and still nothing. Help
  • alex88 Sep 15, 2008
    green power light flashing constantly - black screen
    even when disconnected from the computer(does not give no signal screen)
    backlighting flickers constantly(barely noticable)
    does kick in at random times, works till i shut down
    then goes through the same process.
    usually it takes hours or days for my moniter to work
    pretty fubar - never been dropped, hit or abused
  • dls115 Oct 20, 2008
    Green light flashes - screen is black. Cannot turn monitor off during this time - as if frozen...nothing on screen. Several hours later, the green light turns yellow (like in standby mode), and I can hit space bar or move mouse and the screen comes back up. What's wrong? How can I fix? Do I need a new monitor?
  • Anonymous Oct 31, 2008
    green light flashes.. even when computers off. when unplugged, it stops.
  • Anonymous Dec 25, 2008
    switch flashes on and off..constant on/off buzzing sound..unable to switch the light off..image back to normal after some time,which varies..in my case it ranges from a couple of minutes to over 7-8 hours..hlp very much needed..
My Acer AL1716 monitor will not come on after pressing the on button and no green light.
Posted on Oct 02, 2008
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
Hi!
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Black Screen on W1700 LCD TV
As i said early ther should be an problem with your power card or ram...please upgrade it...
Dec 31, 2007 | AOC LM729 17" LCD Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Acer AL1716B 17" LCD Monitor Logo
823 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
