Question about E-Machines eMachines Desktop PC
Stopped working When computer is turned on the only thing it shows is the red,blue & green square : check pc and signal cable-monitor working.
  • saige119 Aug 25, 2008
    The computer belongs to my daughter.She turned it on and the self check box with the message Check PC & Signal Cable-Monitor working.She checked the cables but still gets the same message
    Scholar:
  • 81 Answers
Hi saige119,
Make certain that you plugged into the right port. And check the other end of video cable.
Posted on Aug 25, 2008
  • 6,487 Answers
So you're saying that there's a display when you reboot your computer it just wont start to your deskptop?? IF there's a display the problem here can be your hard drive ..Please explain the problem further so we can give you the proper solution..
  • Mark Gil
    Mark Gil Aug 25, 2008
    If that's the case this can be a problem with the video card, that might not working fine.. If you can connect another monitor just to check if it work , because if another monitor didn't work the video card is really the problem........
    Master:
  • 521 Answers
The cables are not connected properly.100%.just connect it.it will work like no problem before.
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
Computer powers up, but monitor shows a self test
Your video output is bad. Either the video card, or the onboard video built into the computer. You need to swap out the card or add a card to bypass the built in video port on your computer.
Thanks and please take a moment to rate as fixya.
Feb 11, 2009 | Gateway 550GR PC Desktop
Computer not booting up
Could be one of two things:
1. Signal cable from monitor isn't hooked up. (either monitor end or computer case end)
2. Video card in the computer is damaged and not putting out signal. This is unlikely though as usually this will trip the motherboard into beeping when you turn the computer is turned on.
3.
Jan 15, 2009 | E-Machines eMachines Desktop PC
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
Stopped working
model of the computer ?
Robert
Aug 25, 2008 | E-Machines eMachines Desktop PC
Still having trouble with EMachines T3882
I feel your pain. I finally moved my pc to a room with no windows! But seriously, try a different monitor first. See if you can borrow someone's to just try it before you do anything else. If that borrowed monitor works fine, then you know what the problem is. (Which I believe is the problem.) By the way, what started all of your problems?
Aug 20, 2008 | E-Machines eMachines Desktop PC
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Problem with the monitor
The three boxes represent the built-in diagnostics of the monitor. The letters G is green, B is blue and R is for red, the 3 color guns of the picture tube of your monitor. The words "Self Test" indicates that it is in diagnostic mode since it has powered up, it is also then expecting a video signal from a source to be coming in; the display "Check Your PC And Signal Cable" indicates that it is not receiving any video signal from the source which is your PC or more specifically the PC's video card; and the display "Monitor Working" indicates that the diagnostic has determined that nothing is wrong with itself and therefore it has got to be your PC that is in question. The intermittent appearance of the boxes is when the diagnostics restarts itself and eventually finds the same problem.
To determine if it is the PC or the monitor, use another PC (even a laptop with matching VGA output) and try it with your Compaq monitor, see it it will work or alternately, try a different monitor to connect to your PC. The outcome will determine which is at fault.
If you have determined/verified that it is indeed the PC, you should focus on the video/graphics card. In some PC models/versions, the graphics/video is built-in to the motherboard and you should check the memory since this is shared. The only way is to replace either.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Compaq FS7550 17" CRT Monitor
E-Machines eMachines Desktop PC Logo
26 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
