Question about Olympus Camedia C-730 Digital Camera
Are there any settings on the camera that must be set before you can use the external flash feature?
    Master:
  • 852 Answers
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-40 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Posted on Sep 04, 2005
4 Suggested Answers
neta
  • 852 Answers
SOURCE: Settings that must be set before... the external flash feature
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-20/FL-40/FL-50 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
neta
  • 852 Answers
SOURCE: Settings that must be set before you can use the external flash
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built- in flash and the Olympus FL-20/FL-40 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
neta
  • 852 Answers
SOURCE: Any settings that must be set before you can use the external flash feature
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
In side flash not working
Unless your camera remains under warranty, repairing the flash is usually not cost-effective. Repair is not a DIY option and it must be done professionally. If you visit the Olympus website in your country and go to the service page you will often find that there is a fixed price repair menu on offer.
You may find it's cheaper to fit an external flash to the external hotshoe especially if you can buy a good used flash, but you must ensure that you either use an Olympus or Panasonic model; you may use other independent makes such as SunPak or Metz (expensive, but really worth it) but must ensure that they're suitable for digital cameras. Older flashguns designed for 35mm film cameras can pass too much voltage through your digital camera and damage it. You may also need to activate the external flash hotshoe via the menu as on most cameras it's inactive until selected. Note that an Olympus/Panasonic badged unit will give you full automatic operation, but if you use independent models then you will have to set everything yourself for "non-dedicated" models, and on more expensive "dedicated" models you may have fully automatic operation or may have to enter some settings manually. "Dedicated" flashes are those which have electronics and features tailored to particular camera brands.
Although an external flash is bulkier, the trade-off is that even lowly specified models will far exceed the output of your built-in flash. This enables you to use flash at greater distances and also provides more even illumination of the subject.
Sep 29, 2010 | Olympus SP-350 Digital Camera
My camera don't want to make photos with the flash. I activate it from menu, i opened it manually and the picture is without flash. Why?
The camera does not flash. Solution
sp.gif sp.gif Follow this procedure to troubleshoot the camera not flashing.
  1. Select the correct flash mode . NOTE: When set to the Forced Flash setting, the camera should flash for all still pictures.
  2. Perform a reset procedure .
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Region
sp.gif sp.gif Canada United States Products
sp.gif sp.gif DSCF828 Last Modified Date: 03-04-2010sp.gifID: C322716 document.write(""); ---
How to troubleshoot an external flash that will not work. Solution
sp.gif sp.gif IMPORTANT: Depending on the mode of the camera, the external flash may not be available. Refer to the instruction manual of the camera for more information.
  1. Ensure the external flash is properly inserted into the accessory shoe on the camera.
  2. If using the connection cord, ensure it is properly attached.
  3. If the external flash uses batteries, ensure fresh batteries are installed.
  4. Ensure that the POWER switch on the external flash is set to ON .
  5. Ensure the hot shoe setting on the camera is properly set for the type of external flash and camera being used. NOTES:
    • When using a commercially available standard external flash, ensure the hot shoe is turned on.
    • If a Sony external flash is being used with an advanced hot shoe on a Sony camera, ensure the hot shoe is turned off.
    • It may be necessary to refer to the instruction manual of the camera and external flash for specific information about the hot shoe.
  6. Ensure the READY lamp on the external flash is illuminated.
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Mavica Last Modified Date: 03-04-2010sp.gifID: C292057 document.write("");
Jul 23, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
How do i get to set the external flash mode. I cannot find the setting to turn on the flash. The camera is the Fuji S7000
External flash can be activated in P, S, A and M mode.
Press Menu/OK and use the > until you get to External Flash, and activate it there. Press OK to end.
May 06, 2010 | Fuji FinePix S7000 Digital Camera
External Flash
The aperature error is due to the fact that the lens in not a constant aperature design. The settings on the LCD are assuming you are at full wide angle setting. As this lens moves towards telephoto, the aperature changes about 2/3 of an f-stop due to the mechanical movement of the lens elements. So a manual setting of f4.0 at full telephoto will be more llike f5.0 in reality. It is too bad Epson could not make the mechanical aperature adjust to compensate, but every nice feature costs something. I have not had any issue with the shutter speed changing. One guess is that the camera has shutter speed/aperature combinations that it can't achieve due to mechanical limitations, so it chooses the available combination. Another is that it wasn't in manual mode, but rather aperature priority mode and the final adjustments changed the speed.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
External flash for the 3000Z
bought the Metz 32 Z-2 that was recommended by Epson. I did a great deal of searching/researching on the web, and eventually came to the conclusion (my personal conclusion...YMMV..as well as others) that it was worth the price. I've also had two (non-digitial) pros hold the metz name in very high regard. I like it so far although I haven't used it much for nice portraiture. I did use it at the beach one night in the *dark* from 10 meters (couldn't see *anything* on the LCD when snapping the picture) and a few turned out really nice. Some were not in complete focus, but hey, it was dark. I will say it is much larger than I expected. When mounted on the 850 it felt nice. But with the 3000 being a little smaller, it is rather large. With a teleconverter lens and the flash mounted together, the whole ensemble feels rather nice. I'd recommend finding one in person first. It does have about all the features one could want tho...
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Newer features
4 Nickel Metal Hydride (Ni-MH) Batteries w/Charger included. • 8 MB SmartMedia Card included. On the web it says that Two 8MB SmartMedia Card included. • 6 Step Manual White Balance/ Color Temperature Control. • Burst Mode: up-to 5 images in 1/3 second intervals at any resolution. • External Flash Sync/PC flash connector. • 3 position quick focus settings: 1.3ft, 8 ft., and infinity. • Battery Saving Mode. • Rapid Fire Capabilities all resolution modes (even with the flash on). • 6 Mode pop-up flash system, including Auto, Red Eye Reduction, Fill in, Fill in with External Flash, External Flash and Flash Off.
Aug 31, 2005 | Olympus D-500L Digital Camera
Olympus Camedia C-730 Digital Camera Logo
536 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
