Kitchen Ranges
Problem for Kitchen Ranges
Generic problem for all Kitchen Ranges
Oven door locked and stove
By jkhfg on Aug 25, 2008
oven door locked and stove wont work
Same Problem
Apr 15, 2009
-   same problem. wtf can anyone post a frigg'n solution? -   Guest
Jan 25, 2009
-   Cannot close oven door because lock is out. Oven will work with door open but obviously don't want to use when you can't close the door....I had been baking something, went to pull door open and it wouldn't open so tried again, wouldn't open, then pulled really hard it opened but now will not close....lock is too far to right and hits beside slot instead of into slot.-   suehlee
Dec 23, 2008
-   After cleaning the lock stays on and I cannot open the oven door
-   Guest
Nov 27, 2008
-   the screen on our stove says locked and won't allow us to use it or open the oven door-   bbtrujillo84
Nov 18, 2008
-   After self-cleaning and 24 hour cool down, the door to my 20 + year old Tappan electric range remains locked. The lock/unlock lever is located in the center front of the range in the space between the surface cover and the oven door handle. I do not know the model as I cannot move the stove away from the wall to check the manufacturer information. I cannot find the user instruction manual that came with the stove. Can you help?
Thanks-   Guest
Popular Solutions for Kitchen Ranges
Questions and Unsolved Problems for Kitchen Ranges
Answer
does anyone have an american range and do you like it. i'm looking at a 30" american gas range... (More)
Answer
I may need to buy a new stove. The one that I have now is a Kenmore electric self cleaning oven. It... (More)
Answer
oven lock is on, oven light stays on and I can not close the door or start oven because lock it... (More)
Answer
has a consistant buzz in the upper right control buttons.
Answer
oven wont turn on ireplaced the ignitor still no luck
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Sep 25, 2008
same issue
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kitchen Ranges:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
