Question about HP Pavilion zd8000 Notebook
Power turns on and off.
I was using my laptop and i went home from work and unplugged the laptop from the wall, got home plugged it back in and when i went to turn it on it would come on for 3 secs and the turn off then turn back on then turn off. over and over it would do this. What should i do?
  • iesc108 Sep 02, 2008
    I have the same problem with my HP Pavilion. It's turning on and off constantly.
    When I press the power button, the blue LEDs are coming on, something with the DVD unit is happening and after a few seconds it will power off and then power on and do the same thing over and over and over ......
  • 186 Answers
Try the steps listed below :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power
If the issue persists, try these steps to reset the BIOS to its defaults :
Start or restart the Notebook and start tapping the F10 Key which will take you to the BIOS setup window.
In this, press the F10 Key again to set the settings to its default and exit the BIOS setup screen.
If the issue still persists, make sure that the Power adapter of the notebook is correctly pluged into the Notebook.
Hope this helps...
Posted on Aug 26, 2008
Power went out a few days ago. When it came back on my phone won't work. Says it is out of range. I have unplugged, plugged back in; used a different plug in. Nothing is working.
If you are talking about your smart phone, then it is probably set to use WI-FI for calling and your WI-FI router powered off during the power failure. Find your router and turn it on or unplug it from the wall and plug it back in. Within a few minutes you should be working again. Otherwise, you will have to call your ISP (Internet Service Provider) for help.
Apr 11, 2017 | Power Computers & Internet
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
You need to replace the battery as it has expired.
They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
Hope that helps.
Nov 19, 2010 | HP Computers & Internet
Looks like your battery is having a problem. Remove the battery and replace after a couple of hours. If problem remains replace the battery with another to test, if this works, then the problem is with the adapter unit. Get a new one.
Nov 19, 2010 | Computers & Internet
Computer shut down
The sparking has probably caused your circuit protection inside the AC adapter to turn off the current.
Also, when you are plugging an adapter in,,do not have it plugged into the wall power outlet when plugging into the laptop,,,plug into the laptop first and then plug into the wall.
Jan 29, 2009 | Compaq Presario Notebook
Won't turn on
how old is the system
could be your internal plug for ac may have become lose from plugging and unplugging
or you may just need a new ac cord
try moving it around where it plugs into the laptop if you get a brief connection then it probably is the connection inside the laptop they can be replaced
Jan 16, 2009 | Computers & Internet
Won't turn on
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
Feb 09, 2008 | Akai PT5598HD 55" Rear Projection...
Hp 1315 all in one
The all-in-one product does not turn on If the all-in-one product does not turn on at all, try the following actions in order to determine the cause:
  1. Unplug the power supply from the wall outlet.
  2. Unplug the power supply from the back of the printer.
  3. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Wait at least 20 seconds, then, plug in the supply back into the wall outlet.
  5. Plug in the power supply back into the printer.
  6. Press the power button to turn the printer on.
  7. For models that have an external power supply module, verify that the power supply module is plugged in correctly. Some power supply modules have a green LED built into the connector end or on the power supply module. This LED will be lit if power is present. If the LED is not lit, replace the power supply module.
  8. Plug the power cord into a different electrical outlet. If the all-in-one product has an ADF with an external cable plugged into the back of the product, use the following procedure:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable to the wall outlet, and turn on the power.
      1. If no change, the problem is not the ADF.
      2. If the problem clears, turn off the all-in-one, unplug the power cable, and reconnect the ADF.
      3. If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  9. Disconnect the computer parallel cable from the back of the all-in-one product and try to turn on the product again. The computer might be grounding out through the parallel port. If this corrects the issue, check the grounding of the computer and outlet.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Pavilion zd8000 Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
