Question about Refrigerators
Na water comes out i changed the filter still no water
  • Anonymous Nov 06, 2008
    I have the same problem. However, I changed the filter and reset the button. Still no water.....
    Problem Solver:
  • 16 Answers
I have the same refer. Has been nothing but probelms. The water freezes at the dispensor. Take a hair dryer and heat the dispensor up until it thaws. Sometimes you can take a piece of weedeater string and feed it up into the line to see how far back the block is. I had to repalce my defrost heating element twice already. Not difficult at all. The 1st time the repair man charged me 200 bucks. The next time i did it myself for less than 40 bucks. Of course GE will not mention that they have a new element that now goes into this refer. Should have been a recall in my book,
Posted on Jan 06, 2009
I have a GE side by side refrigerator (Model#GSS22WGPH BB). I have changed the water filter (Smart Water filtration) and cannot get it again dispense water. I filled the new filter with water prior to installation and pressed the reset button.
Posted on Nov 05, 2008
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
Mahina na po kasing humatak motor ko tmx 155 siya na nakasidecar, napapansin ko kasi na pag paakyat na ako bigla siyang manghihina.. hindi tulad ng mga ibakung kasama na malakas pa rin hatak ng motor nila...
bro' kumusta,
madaming pwedeng posibilidad yan, poor compression, poor spark, poor combustion. Check mo muna yung carburador niya.. dapat ang ikot ng fuel-air mixture e 2.5 turns out. Tanggalin mo yung air box at linisan yung filter nito.. tro mo din patagbuhin panandalian na walang air filter.. kasi pwede barado na ang intake nito. Check mo spark plug at siguraduhing malinis pa ito. Panigurado e palitan mo nalang ng bago.. check mo din na dumadaloy na maayos yung fuel papunta carburador.
kung ayaw mga to, pa-compression check mo para masuri ito ng maigi baka kasi maluwag na yung piston rings or piston nito.
sana nakatulong,
parate naman kung sakaling natulungan ka nito
salamat
Dec 27, 2010 | 2005 Honda CG 150 Titan ESD
Reset water filter light
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place. Let me know if you need the complete manual, Thanks, Sea Breeze
Apr 16, 2010 | Maytag MZD2766GES Side by Side...
I changed my water filter and now i need to turn out the filter warning light.
(Select Models)
FILTER
Please rate me!
Thanks, Sea Breeze
Mar 22, 2010 | Maytag MZD2766GES Side by Side...
I changed the filter for the water dispenser and after purging the water for awhile, the dispenser stopped working. What needs to be done to get the water dispenser to work again
Put the old filter back on , if water was fine . You never change filter just because a light comes on telling you to . The change filter light comes on after time or usage of dispensor .( Good way for manufacturers to make extra money ) . Change the filter only when water flow slows from dispensor .
Aug 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Whole house water filter , NO water coming thru
Good morning! please try to uninstall the water filter, then observe if there's water flowing on the tube, if there's water flowing then it might be the shutoff control valve that is defective which mean that we have to replace it. best regards
May 05, 2009 | Plumbing
Changed filter water leaking out of ice maker even when shut off
if u have changed the filter and it wasnt letting water though before you changed it, then some foreign material has come out of the filter and has wedged its self under the plunger of the water solenoid holding it open
Apr 28, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Renault clio 1-5 dci (2002)
Hi there!
It's very likely a valve stem seal that has split. This will allow oil into the cylinder from the crank gallery.
Off with it's head! I'm afraid.
The only other thing it can be is overfueling - but then it will be sputtering and lagging on acceleration.
You can check which cylinder is affected by removing the plugs and looking for the oily one. They will all need replacing really as it's false economy to do just 1. The seals are cheap. I would get a new cambelt fitted at the same time - as it has to come off anyway.
(If this leads to a solution, please take the time to rate as Fixya! - Thank you)
Jun 17, 2008 | 2003 Renault 181
Refrigerators Logo
273 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
