Question about Refrigerators
Magic Chef Freezer Runs Constantly
I have a Magic Chef fridge. The freezer runs constantly, only shutting off for about 20 minutes a day. This is a 2000 side by side. We have had the thermostat replaced and are seeing no change.
huuum
  • 750 Answers
SOURCE: Freezer runs constantly
Hello okons ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Your freezer will not stop running, it's very cold.
I see that you did off and on!
Did you turn it off and then unplug it? Or if for some reason you can not reach the plug, turn the breaker off instead!
Leave it off for at least 3 minutes to your watch!
Then when you return power to the appliance and turn it on, it will reset itself and perhaps this will remedy the problem!
If it does not remedy the problem I would say the thermostat is faulty.
Let me know what happens!
Bless You, Huum
How old is the freezer?
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 23, 2008
huuum
  • 750 Answers
SOURCE: Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Posted on Jan 09, 2009
SOURCE: Magic Chef Refrigerator
I've had a lot of experience with this problem in Magic Chef refrigerators. It was the fan motor in the freezer section not working. It is a fairly easy item to change out and the part runs about $40.
Posted on Jun 11, 2009
woodchuck789
  • 4070 Answers
SOURCE: Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Posted on Jul 09, 2009
Magic Chef Fridge & freezer not cold-both fans running-Compressor hot- cleaned drain tube-outside of fridg cold
Is compressor running continuously or is it clicking on and off every couple minutes? Is there any frost buildup on inside back wall of freezer?
Sep 26, 2017 | Magic Chef Refrigerators
Red light is on all the time, wont stop running
Some freezers have a pilot light that is constantly on whenever power is being applied. If the compressor seem to run constantly, check for a bad lid seal. Also, the thermostat may at may be defective
Jul 19, 2013 | Magic Chef 5 cu. ft. / 142 liter Chest...
Have magic chef mccf5wbx freezer compressor runs but shuts off in 15 seconds
Check condensor not clogged up, fan working etc. If all ok, try new capacitor and relay. If all else fails, replace freezer (compressor replacement is costly)
Aug 07, 2012 | Magic Chef Chest Freezer MCCF5WBX
Refrigerator and freezer not cooling adequately
the ptc overload on the compressor is defective,replace this and it will again cool properly
Feb 16, 2012 | Magic Chef Refrigerators
The freezer constantly drips water even with the ice maker turn off, the fan constantly runs but when the door is open the fan shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Microwave Ovens
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
CTB1722GRW compressor clicking on for 20 to 30 seconds then off.
it depends on how severe the power spike on the outage was,if your lucky it may just be the contactor,if not comp time,you can open the contactor case and manually start the compressor,use an insulated non-metallic device to do so
Jul 20, 2009 | Magic Chef CTB1722 Top Freezer...
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
