Question about Kenmore Elite HE4 Electric Dryer
Problem F2 on HE3T washer
How do I check that the water is running freely from the tub through the drain line? My husband is having a hissy fit about \this machine and I'd love to solve the problem. Thanks. You are a genius!
PS -- My machine is the HE3T model number 45966 but I'm sure the f2 problem is the same.
    Genius:
  • 1,028 Answers
Remove bottom panel ..try to remove as much water as possible wet/dry vac will help//remove the clean out port on front of pump housing ..have towels handy..clean out as good as possible also be sure to ck around impeller in pump mouth.. reverse and ck operation
Posted on Aug 27, 2008
HE3t leaves water in drum after the wash cycle is complete. Already checked the drain clean out...still leaves water in the drum.
Since we are working on the drain side of things only 2 things can happen to not get the water out of your tub-1 the pump isn't working,something stuck in it- 2 you have blockage which we know is not in the trap-check conection to the tub and the pump and all discharge hoses-cheers Denny
Oct 15, 2013 | Kenmore HE3T Washer
Have checked all recomended trouble shooting suggestions- there must be more?ot drain or spin, motor running, all lines have free flow of water, nothing between tubs and pump pulley moves freely. can
although the pump will turn by hand . when you use the motor power and the belt tenson;. it may be binding. ( this has been a common problem. ) ck for play in pump shaft and look for black under washer from belt fraying . my guess is the pump and also replace belt with the pump // hope this helps. **** and thanks for using fix ya ..
May 04, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Fills with water and does not drain
It won't drain If your washer won't drain, check these: It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.. It doesn't spin or pumpIf your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.It pumps, but the water returnsIf the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
Jan 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have the kenmore HE3t and the door will not unlock. The suds error message is on and the machine keeps running and running. What to do?
You may be experiencing a momentary program glitch. First, UNPLUG the washer for at least 30 minutes to reset the Central Control Unit (CCU). This is the main computer.
Following a CCU reset, attempt to do a DRAIN/SPIN to get rid of the water in the tub, followed by a RINSE/SPIN to get rid of an excess suds. You may have to repeat the process of RINSE/SPIN a few times if the suds are really excessive.
If the error persists, you may have to check the drain system for anything that may be restricting water flow. Primarily, the drain pump reservoir and/or the drain lines. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Do not forget to check the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump. Sometimes small garments can find their way into the drain line and plug it up.
If you cannot get the door to unlock, there is a manual release you can use to retrieve your garments. The following link explains:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
You may want to attempt to drain the wash tub before opening the door (if full). If you have any questions, or if you continue to experience problems, please post back and let me know. I hope you find this information helpful.
Mar 01, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front-loader washer doesn't drain all the time. Seems pretty random. Took off the front cover and checked the filter basket several times - didn't see any evidence of blockage in the pump. When...
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 29, 2010 | Kenmore HE3T Washer
Won't drain yet no clog or knk in line
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 17, 2010 | Washing Machines
HE3t front loading washer-F2 alarm
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a error code coming up saying E:04. Any solutions?
It has been 2 1/2 weeks since this was posted so it has already been solved probably. Open the basket on the pump to see if the water is draining freely from the wash tub. (You can access the basket by removing the round panel in the lower right corner of the front panel). If the water is freely draining, check for plugging of the drain line from the pump to the outside. If the water is not freely draining, remove the rubber boot between the wash tub and the pump and clean out the debris around the ball at the wash tub end.
Apr 11, 2009 | Bosch WFMC2100UC Nexxt Essence Washer
F2 & Alarm problem with cloths
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F2" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F2 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. globul1a.gif Check the drain hose and make sure it is not plugged or kinked. globul1a.gif Check the electrical connections at the pump and make sure the pump is running. globul1a.gif Check the drain pump filter for foreign objects. globul1a.gif If the above does not correct the problem, replace the pump.
These are the possibilities for that error code at one web site:
Press PAUSE/CANCEL twice to clear the display. * Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
F2 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F2 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F9 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F2 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Feb 15, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Top load washer will not drain
just by your descriptions,you may have trash/blockage in the screen/filter on the inlet side of the pump.to check this before pulling anything apart,take the drain line(with water in the tub of course)& drop it well below the water line in the unit(use a bucket).the water should run fairly fast out of the washer,if not you have a blockage.be sure to get as much water out of the tub as you can if you attempt this yourself.either way let me know & we'll see if we can get it corrected.thanx for using fix-ya!!!
Nov 14, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
