Question about Asko Dryers
Loud banging noise when drum turns - Asko Dryers
    Sergeant:
  • 351 Answers
Drum rollers
Posted on Aug 27, 2008
Whats wrong with Dryer
The drum slides at the front are made of felt. Yours have worn away. The drum is banging up and down. If you open the door you will find that you can lift and lower the drum. If you drop the drum, you will hear it bang. They are easy to replace if you can get the front off the machine.
It could also be that the rear drum bearing is worn, but that doesn't normally make a banging noise. It is a metal spindle attached to the drum into a nylon sleeve in the back of the machine.
Nov 04, 2015 | Dryers
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
My Amana LW4303W washing made a loud bang noise,
Hi.
You have broken the drum bearing, it is the part located at the bottom of the tub, the drum bearing if fixed at the back of the drum.
Here all parts and diagrams for your model.
Regards,
Nov 14, 2009 | Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Banging Noise in Kenmore Dryer
There are two rollers that hold the drum in place. I'm betting that one of those rollers have broken or fallen off. It's not a very easy fix since you'll have to take the dryer completely apart to fix it. Good luck!
May 25, 2009 | Dryers
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Dryer making loud and louder noise after about 5 minutes of use
my dryer started making a very loud banging noise when I turned it on. It heats up and the drum turns, but I am afraid to use it.
Apr 22, 2008 | Kenmore Dryers
Dryers Logo
160 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
