Question about Eclipse Premium 34230 Car Audio Amplifier
Help my fuse is blow!
I need help figuring out why I keep blowing 2 fuses. I have the amp running 2 dvc 4hm 10" subs. as soon as i turn key fuses blow! any answers for me?
  • 631 Answers
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Let me know if you have any other questions.
Posted on Aug 26, 2008
My GMC Envoy keeps blowing the 10 amp fuse for the heaters.I unplugged the front blower fan but it still does it. Is the other fan in the consul?
The fuse isn't for blower motor. I saw a fuse 39 and fuse 36 both 10 amp, both for hvac. I don't know which one is blowing? One fuse is for actuator doors under the dash, the other is battery voltage to hvac control module. One is hot all the time, the other goes hot with key on.
What is model year? Does it blow as soon as you turn on the key? Any applicable hvac trouble codes? About all I can do is track wiring circuits.
Nov 08, 2017 | GMC Cars & Trucks
Keeps blowing auto shut down fuse as soon as key is turned on
Could be several things including one of the oxygen sensors, one of the injectors, the coils, or the engine computer.
You will probably need to get a shop manual to get all of the wiring diagrams connected with that circuit. And I would suggest you use a circuit breaker to check each one instead of fuses.
You'll have to disconnect each component until you find the short.
Oct 18, 2015 | 2004 Chrysler Town and Country
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
It keeps blowing a fuse
Generally, if you are using the manufactures fuse rating you can use a slightly higher rating and it will resolve the blowing fuses. Fuses supply resistance, if there isn't enough resistance you'll fry the system board in the amplifier. But if you have 25 amp fuses installed, install 30 amp, if you have 30 install 35 amp, 35 install 40. Anything higher will damage the amp.
Hope this helps.
A rare chance, something may be internally wrong with the amp and shorting it out which will blow the fuse.
Use the incorrect wiring of subs to the amp, you'll blow fuses and damage the amp from it turning off consistently. The amp should be running at 2 ohm stereo stable or 4 ohm mono stable.
Very few amps are designed to run at 1 ohm or less. Not to mention the subs can't handle it.
Jul 28, 2010 | Power Acoustik TS980-2 2 Channel 980W...
What do you do when your amp keeps blowing fuses
First off which fuse is it? The inline fuse from the battery or the amplifiers power supply fuse? Blowing the main fuse from the battery is caused by either the load (your amp) drawing too much current or you have a short to ground somewhere. Maybe there is a tear in the 12Vdc line and it is shorting to the chassis of your car. If the amps power supply fuse is blowing as soon as it turns on your amp has a shorted power supply. This will require internal component changes by a technician. If it is blowing after operation at high volumes I would say change the impedance that the amp is driving. If you are at 2 ohm try to rewire your speakers for four ohm. (go from parallel to series wiring then bridge mono or operate the amp in stereo mode)
Feb 07, 2010 | Infinity Reference 1300a Car Audio...
I have a 1998 chevy blazer (s-10) 4.3L 4x4 it keeps blowing the #15 (10amp) 4wd fuse, if you put a 10 amp fuse in it will blow the minute you turn it on ,then we put a 15 amp in it seems to do it when you...
check transfer case electrical switch, sometime if it bad it will also blow the fuse. don't recommend you put any higher fuse than recommend, If the fuse blow there is a short some where and by putting higher amp fuse you might short or burn something else beside the fuse. if that check out than check your transfer case motor, might lock up and not allowing the motor to turn instead it short the fuse. don't drive the car, just leave it in park, put correct fuse amp back in and unplug transfer case electric switch and turn the key on (dont start the car) and see if the fuse blow; if not plug it back in and see if it blow the fuse. if that is not the case, unplug transfer case wire, and do the same and see if it blow the fuse.
Jul 12, 2009 | Chevrolet Blazer Cars & Trucks
Fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Jun 17, 2009 | Garden
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
2nd Basslink, still no power-on. Please help
this is in response to the post below:
I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! s@#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
Jul 15, 2008 | Infinity BASSLINK Car Subwoofer
AMp keeps blowing fuses
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Apr 25, 2008 | Car Audio & Video
Eclipse Premium 34230 Car Audio Amplifier Logo
175 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
