Question about Philips DCP855/37 Portable DVD Player
Turns on but won't play DVD
My son's dvd player will spin the dvd and I hear it trying to work but the movie won't play. The screen is lit and the words loading is on but nothing else happends. Is there anything I can do? I thinking of cleaning the inside and using a air can to it a little.
Any advice?
Barbara
  • 2 more comments
  • Anonymous Sep 12, 2008
    dvd player want go past root menu
  • anh_t_le Sep 14, 2008
    Exactly the same problem. I wonder if my son drop the player and so the laser reader head if off track
  • kduncan58 Sep 30, 2008
    I have the exact same problem. Some times I can get it to play a bit but then it locks up on a screen - almost like a skip. Very frustrating since it is less than a year old.
  • BHLovell Dec 14, 2008
    I heard my 2-year-old daughter yelling at her DVD player today (she usually changes the movies herself with no issues) and when I went to investigate I found the same issue... The player won't recognize any DVD I put in.
I have one of these players from philips,and it is just out of waranty,and it was only used about six times and now it won't read the dvd's anymore.PURE JUNK DON'T BUY.
Posted on Nov 07, 2008
Do I need a remote control to control the Philips magnavox model DVD 815AT. It plays the commercials on the video disc. When it comes to playing the movie, it keeps repeating itself and it won't go...
Usually most DVD's play movie trailers and sometimes advertisement before the movie will play. Once the ads or trailers are done it should go to the menu screen and at that point "play" or something like that should be underlined. If it is you can press play or select on the DVD player then the movie should start : )
Jul 27, 2011 | Philips DVD815AT DVD Player
Dvd movies plays on computer but on in dvd player
Try to make a backup copy of your DVD there is so many program free on internet thaat you could get good luck!
Feb 20, 2010 | RCA DRC8300N DVD Recorder/VCR
Won't play movie
sounds like the dvd is bad, try another dvd if that doesn't play then it is the player.
Nov 15, 2009 | Polaroid PDV-0700 Portable DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Movie is playing, but will dont display on screen
Try increasing the contrast. If that doesn't work, then make sure your input is on the correct setting. Press the input button and wait for a picture to load (about 5 seconds each) while trying to play a DVD. Also, make sure that the backlight is enabled. If you take it out into the sunlight and you are able to see a faint image of the movie on the screen, then you need to turn your backlight on. Most likely an option in the main menu, but it may also be caused by a broken sensor that senses when the player is closed and turns the backlight off, but also turns it back on when the player is opened.
Feb 11, 2008 | Zenith DVP615 Portable DVD Player
Problems to play any dvd at my DVP-NS575P
sir,,,your appliance needs maintenance,,,,u need to clean your dvd player especially its lens but be careful you might destroy it,,,use ligther fluid or any in cleaning liquid materials but it should evaporate fast,,,,thnkss and hope to help you thnksssssss,,!!
Jan 29, 2008 | Sony DVP-NS300 DVD Player
Movie does not play
Try playing Different DVDs, Second Make sure which Region Disk your playing is it Region 1 or Region 2, If your DVD player is Manufactured in USA it plays only Region 1, If its manufactured in UK it plays only Region 2, If still you face same problem Use Lens Cleaner, If still you face same problem do Reset.
To Reset Dvd player, Remove DVD from Dvd Player, Unplug Power chord from Walloulet for 15minutes so player goes to Defult Factor Settings, Then plug back again Power chord. Turn on Dvd player insert DVD, It should Play or else Claim Warranty.
Nov 14, 2007 | Curtis DVD8017 Portable DVD Player
MY SAMSUNG DVD+VIDEO COMBO V4600
What you're describing is a common problem for this particular unit, a bad spindle motor. In some cases the motor can be removed by the tech and torn down for cleaning.. But in a high percentage of cases shops just replace the motor... What's happening, as your symptom appears the spindle motor is beginning to spin irratically. In turn the picture can sometimes just drop out. In others it simply folds over and is unwatchable. The spindle motor is not too expensive.. Good Luck Bill
Jun 10, 2007 | Samsung DVD-V4600 DVD Player/VCR
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
DVD PLAYER
Hi Koji, My Toshiba DVD player does the same. It stops playing the disc, and the icon for incorrect disc displays. Often I cannot even start a movie. I keep getting BAD on the readout display also. I try hitting the player, or the stand in which the player is sitting, and sometimes it goes away and the movie plays. I will never buy Toshiba again.
Dec 25, 2006 | Toshiba SD-3980 DVD Player
Philips DCP855/37 Portable DVD Player Logo
305 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
