Acquiring network address
I suddenly cannot connect to my wireless network. My husbands computer has the d-link 802.1. His computer is working fine. My computer about 20 ft away has the d-link drive and where it can find a network it cannot aquire it.
What has happened and how do I know if it is the router or not?
Sue
  • 60 Answers
It would be best if you have another wireless computer maybe a laptop so you can further isolate the problem, you can check if the other wireless will encounter the same problem. If that is not possible, make sure to check the wireless settings on the router, take note of the ssid, channel and wireless security. Try to reconnect again. if same problem exist, try changing the channel on the router.
Posted on Aug 25, 2008
Dell inspiron e1405 cant acquire a network address?
Call Dell customer support phone number 1-800-204-4427 to get online help for technical problems related to Dell computer, laptop, printer, scanner and tablet Dell Laptop Support Phone Number 1 800 204 4427 Tech Help
May 17, 2017 | Dell Inspiron E1405 Notebook
Using Nintendo Wireless Adapter - No Connection Anymore
If available networks are found, it means that the wireless adapter is working just fine. In case of Wi-Fi, the device has to acquire an IP address from the wireless router and the mutual communication is not taking place. This has something to do with the wireless router. Check for any kind of security filtering like MAC address filtering or lower down the encryption technique to 64-bit WEP. Try connecting to even an unsecured network, then check for the automatically acquired IP address. It should never be starting with 169.254.xx.xx (Invalid)
If you have other wireless computers going online in the same network, without security and filtering, then it means that your DS Lite is not acquiring an IP address. In that critical case, you may have to statically or manually assign an IP address in the range of the router.
And lastly, as you said LAN connection is active, it would be because it doesn't face any hardships while connecting!
Thanks..
Do get back if you need further clarifications.
Mar 18, 2010 | Computers & Internet
No wireless on Time-Warner cable. LAN works fine
Yes, from what I understand you need a special router to go wireless with timewarner, just another way coporate America dicks the regular guy.
Dec 18, 2009 | D-Link DIR-615 Wireless Router
Trying to set up a second computer for wireless
What wireless mode is you router operating in? Does it support the cards on your other systems?
Do you have mac address control enabled?
Try disabling security temporarily to see if you can connect; your wireless connection may not be setup to authenticate properly.
Nov 16, 2009 | Belkin Computers & Internet
Cannot acquire network address but sees router
You can first disconnect ur network name form router and then give a static ip in the range of the router on the wireless n/w connection of ur computer and then try to reconnect. Computer will automatically pick up the address and get u online, if problem still persists then reboot the comp once.
thanx and regards
sukhiii
Jul 24, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
I am trying to connect to the wireless in my new apartment. I have entered my network and password and that has worked fine. However, under Wireless Network Connection Status (i can get there by clicking...
On the Support tab - what does it say the "Address Type" ?
If its DHCP then check that on the TCP/IP properties;
If on "automatic IP address" then it wont take any entered IP address.
Do not put any IP address.
Check that "Obtain an IP address automatically" is checked and also "Obtain DNS server address automatically" is also checked. On wireless network tab check "Use Windows to configure my wireless network settings".
On preferred network check that your wireless network is there, if not add it and move it up
Jan 26, 2009 | Dell Inspiron 2200 Notebook
Having Problem Acquiring IP Address
when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 19.168.0.240. Hope that helps.
Dec 25, 2007 | Linksys Wireless-G Range Expander (WRE54G)
Card does not acquire ip address. repair does not work defaults to 169.254.244.38
What is the network adapter connected to - a modem or a router? Is there any other computer or device that is connected to that modem or router and is able to acquire an ip address? This would generally happen when the network adapter is not able to automatically negotiate with the connected device (which might have 10/100 ethernet ports). You can resolve this by forcing the network adapter speed to, for instance, 100 mbps. Please revert back with further observations.
Apr 16, 2007 | GigaFast Ethernet EE110-AXP (EE110AXP)...
Cannot connect wirelessly, but can through my network cable
After a few tries and re starts it may connect itself, but if not go to Start>Run, then type 'ipconfig /flushdns'. Try connecting again, but ensure your wireless card is set to obtain IP address automatically and you have enabled wireless connection and DHCP in your routers menu. Hope this helps
Dec 05, 2006 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
780 people viewed this question
David Payne
David Payne
