Question about Haier hwr10xc6 Air Conditioner
Haier HWR10xC6 air conditioner
The buttons on my panel only stay on cool and fan, nothing else. We tripped the circuit this morning...could this be it?
The control panel is not working properly. The ac will come on but cannot set any of the controls, e.g. temperature, time. We replace the control board with a new one but are still having the same problem. What now???
Posted on Apr 26, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
HEY< the only thing to tripp the breaker is commpressor pulling too many amps due to running hot by not getting rid of enough heat thru the back coils. I bet the inside of the back coils are getting plugged up! Thank-you-very-much!
Posted on Aug 30, 2008
We have a ESA406K-L Haier 6000 btu and the reset button keeps tripping are air conditioner will not turn on at all.
Is this reset on the plug? if so its likely bad, bypass and test, if it works get another end or wire to a fused disconnect which would be jn place of, unorthodox, but safe.
Aug 30, 2011 | Haier hwr10xc6 Air Conditioner
Do i need water for my haier HWR10XC6
No... it will produce water when cooling..
heatman101
Aug 25, 2011 | Haier hwr10xc6 Air Conditioner
Just put air conditioner back in for the summer.. plugged it in and ran a test on it then nothing... any suggestion why it wont turn on..
Could have quite possibly tripped the circuit breaker. If it is a 230volt unit, there will be two breakers, they are usually joined together and probably 20 amp. Trip them all the way back and then all the way forward. If it is a smaller 120 volt unit there will only be one breaker, more than likely a 15 or 20 amp. Hope this works. Also, on newer models the plug may contain a reset button. It will be right on the head of the plug itself.
May 13, 2011 | Haier hwr10xc6 Air Conditioner
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Haier HWR10XC6 Air Conditioner - Where's the "Vent"
the vent can be used to provided some quantity of fresh air,which is located betwen inner blower and outer fan blade. the operating knob is provided in the front panel.
Jun 02, 2009 | Heating & Cooling
Not cooling just feels like the fan is on.
HEY, sounds like it time for a full clean-up. Take the cover off and clean the drain ports, the filter in the front of the unit, the back inside coils, oil the fan motor, wash the front coils, ,, The water blowing out could be because its not leanning back enough, & the coils or filter is plugged and trying to **** air anywhere it can ,even thru the drainnage system! Thank-you-very-much!
Aug 30, 2008 | Haier hwr10xc6 Air Conditioner
I have an E8 error message on my Haier hwr10xc6 Thru-Wall/Window Air Conditioner
I had a problem with my Haier Air Conditioner also and was getting an E8 error message. We had taken the air conditioner out to clean it and when we put it back in all we could get was the E8 error message. We tried several different things so I don't know if it was a combination or luck. Here is what we did.
First we tried holding in all the buttons on the panel and another person hit the on/off button on the remote (per a suggestion on the internet). The fan stayed on, but the compressor would cycle and it would get cold for a few minutes then kick off, but we never could get the buttons on the control panel to work. Nothing happened when we pushed them.
Then we checked the thermostat (the little tube in the front) . The thermostat tube was touching the coils. We rearranged the tube so it was not kinked or touching the coils. It was then getting cold, but we couldn't control the buttons. So we unplugged it (reluctantly because it was cool then) and plugged it back in and it started working. Hope this helps someone! I don't know if what we did worked or the mother board got wet and just happened to dry out or something.
Jul 24, 2008 | Haier hwr10xc6 Air Conditioner
Compressor turns on but unit doesn't cool.
take the air filter out and see if there is a dramatic improvement - if so clean the air fitler - otherwise it may need regassing
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Haier window air conditioner
I suggest you check the ground of the wall socket. Many three proung sockets are not grounded.
Sep 03, 2007 | Haier hwr10xc6 Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
207 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
