Question about Canon imageRUNNER 2200
CANON IR 2220 POWER PROBLEM
MACHINES LOSES POWER WHILE IN WARM UP. THEN TURNS ITSELF BACK ON AND LOSES POWER AGAIN IN WARM UP.
  • rgarris Aug 26, 2008
    CANON IR 2220 MACHINES LOSES POWER WHILE IN WARM UP. THEN TURNS ITSELF BACK ON AND LOSES POWER AGAIN IN WARM UP. IT DOES NOT SHOW ANY ERROR MESSAGES, IT NEVER GETS OUT OF THE WAIT MODE, AND DOES NOT GO INTO REGULAR DISPLAY.
  • Canon Expert
  • 1,326 Answers
Does it show error code? Also does it ever get out of the wait state? The "bar" at the bottom? Also, does it ever go in to the regular display sceen? If the display turns black, do you see a code or numbers like "602-001" ? Need some more info then just turns on and then off
Posted on Aug 26, 2008
  • Chris Coughlin
    Chris Coughlin Aug 27, 2008
    You could have a hard drive that has failed. It also be a PCB problem. Do you have a service contract on your copier? If not it could be very coastly to fix. You have not given enough info. to go by..... Just ON and then OFF. It should be showing something else. Whish I could help, but I'd be guessing????
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
How can i resolve the error code of E002-0000 on IR 2202? when i switch on it mark that error and refuse to operate please help us
I believe that model number is wrong......You must be referring to a Canon IR 2200 or maybe a Canon IR 2220. The Fuser has a problem when warming up. Replace the fuser or the Fixing film assembly and then the error must be reset in service mode.
Dec 03, 2014 | Canon Office Equipment & Supplies
Error code e000602
Mounting fault of the HDD.Viring faulty.The main controller PCB faulty.Wiring between connector J1025 of the main controller PCB and the connectorJ 2005 of HDD,or try reinstall the system software,or try to replace HDD and download the system software,or replace the main controller PCB...
Sep 25, 2014 | Canon gpr-6 ir 2200/2800 drum...
I have an Epson V500 scanner. Whenever I plug it in / turn it on it cycles through it's warm up and then shuts itself off. I can pull the power plug out and then reinsert it to turn it back on. Bu
sounds like an internal part is heating up and shorting out- I know this will sound crazy, but put scanner in fridge or outside if you have cold nights, and see if it stays running longer before quitting.
Jan 04, 2013 | Epson Perfection V500 Flatbed Scanner
Nokia 2220 wont turn on
This situation in phone servicing called Dead;there are many reasons for being so.You have to try sometips here-1-Take off batteryand clean the node with brush then put it back and press power button.
Nov 20, 2011 | Nokia 2220 Cell Phone
Canon 2220 "ROM ERROR" and won't work.
First Unplug the printer for 10 minutes. Then start your printer it will work fine.
Then execute eprom clear in Test mode.
If you still face the problem then there is a bad solder connection or a power surge. Loose wire is always possible.
Hope this helps.
Shane
Feb 15, 2011 | Canon imageCLASS 2200 Black and White...
Screen loses power frequently. Comes back on by itself
If it does comes back on by itself, make sure that the vga cable is properly connected on the vga port on your computer. Does the led light on the monitor turns from green to amber? if yes, check for connection cables and the power cable.
Please let me know how this goes. Thank you for using FixYa.
Jan 20, 2011 | Samsung 2243BW Monitor
It turns itself on and off repeatedly
Try this:
Unplug the tv let sit for a minute while you replace the batteries in the remote and cover the IR remote sensor on the front of the TV. Cover it with a piece of black tape or a piece of aluminum foil.
Plug the tv back in and turn on.
If it no longer turns on and off by itself then you have IR interference from some other remote operated device in the room.
If it does continue to turn on and off with the IR sensor covered then it is the internal wiring/processors and will need servicing.
May 12, 2009 | Sanyo DS27510 27" TV
Canon imageRUNNER 2200 Logo
277 people viewed this question
old marine
old marine
