Question about Pioneer Car Audio & Video
I have a AVH-P4050DVD when i insert a cd it gives me the error message "error 02-9E" it will play dvd's but not any form of audio cd!
3 Suggested Answers
zzedly
  • 300 Answers
SOURCE: avh-p5900dvd... I keep getting error
Owner's manual doesn't really say what the -02-9e error code means other than a disc error. They do recommend resetting the unit as a possible solution:
  1. Turn the ignition off.
  2. Remove the faceplate.
  3. On the right side of the front of the head unit (with the faceplate removed), press the reset button with a ball point pen.
You may have to call Pioneer directly to find out what the -02-9e code means specifically. 1-800-421-1404
Posted on Apr 03, 2008
zzedly
  • 300 Answers
SOURCE: avh-p500dvd... I keep getting error
Double post. Please see newer post.
I have a pioneer Avh-x5600bhs and am trying to play audio on a DVD. Some songs play, but I get two error messages. 02-99 and 02-a9. Any ideas? Thanks
Your manual should say what kind of format it playes, and this link is good explanation ,also some burnt dvd do not play cause the player does not have the proper driver of internal decoder .
https://www.youtube.com/watch?v=cnDI10ksHyI
Feb 23, 2015 | Pioneer Car Audio & Video
Not getting any sound from my i-pod Pioneer AVH-P4050DVD
I had the same problem with my Pioneer AVH-P4050DVD
Radio and CD worked fine
DVD would play and I could hear the audio but no video
USB and iPod. It would connect and I could brouse, select and play songs but I would not get any audio even though I could see the track playing, finnishing and moving on to the next one (very frustrating).
Front Aux (Aux 1). I could turn this port on to audio, select it and plus an audio sorce in but no audio would come out.
The solution..
The Pioneer AVH-P4050DVD is odd and different from most other pioneeres in that it has two earth leads that both need to be grounded (2 in addition to the handbreak wire). I had insalled my unit using a toyota - pioneer wireing adaptor I bought from Repco. This adaptor only grounded the wire coming from the corner of the plug (opposite the battery wire). The second earth is located becide the first earth, opposite the ignition wire. If you google pioneer 16 pin wiring diagram it might call this pin BGSENS (pin 13 in the attached photo). With the wireing harness I had this pin was not connected to anything. Once I grounded the second earth (soldered directly to the first earth) everything worked.
Good luck. Hope that helps.
Jan 11, 2013 | Car Audio & Video
"No disc inserted. Please insert the
No disc inserted.
Please insert the original "FIFA 09" CD/DVD.
Jun 30, 2011 | Computers & Internet
Hi, I have Windows 7 on my MSi L1350 laptop. Whenever I try to play a DVD on my RockSoul DVD Multi Recorder (RW) on Windows Media Player, I get the following error message: "Windows Media Player...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or
http://majorgeeks.com/Realtek_High_Definition_Audio_for_VistaWin_7_d5513.html
hope this helps
Apr 04, 2011 | Toshiba ROCKSOUL ED100 USB slim external...
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    I just don't know what program and format to use so I can listen on my AVH-P4900
    It can play Audio CD, MP3, WMA, including formats like Video CD (VCD), DVD, Div. It has 4 channels, with In-Dash Player, In-Dash Monitor. Th inputs it recognizes & plays are DVD Video, VCD, SVCD, DVD-R, DVD-RW, CD (Audio), CD-R, CD-RW. In the radio you can hear AM, F. It has a 6.5 inch dipla. A quote from their website reads "The AVH-P4900DVD lets you take your digital music files with you, whether they're MP3 or WMA format. Burn files onto one CD-R and play them in any mix you want. Use the touch-panel to easily navigate through your file and folder lists to find exactly the song you are in the mood for." I hope this is enough to answer your query!......sodeep
    May 08, 2009 | Pioneer AVH-P4900 Car Video Player
    My computer wont let me play any of my cd/dvd/softwaredisc...
    I assume you're referring to music CDs. What media player are you useing. What happens when you open windows media player and hit play --> CD audio? Any error messages?
    The CDROM drive may be bad.
    Jul 24, 2008 | Dell Dimension 4600 PC Desktop
    Yamaha DVD S520
    yes sir, starting to malfunction and needs replacement now. unless you cant ry cleaning it manually maybe it will help a little but sooner or later it will again give you same trouble
    Aug 03, 2007 | Yamaha DVD-S520 DVD Player
    Error message
    try removing power from the unit for about 5 minutes and plug the harness back in. If that doesn't work, it will need to be repaired.
    Apr 09, 2007 | Pioneer AVH-P6500DVD Car DVD Player
    Car Audio & Video Logo
    Top Pioneer Car Audio & Video Experts
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
