Question about Samsung SCX 4200 All-In-One Laser Printer
Open heat error on Xerox Workcentre PE120
I have an "open heat error" on my printer, and unplugging it and plugging it back in after a few minutes doesn't fix it. Doesn't that mean I need to replace the fuser? Is that something I can do myself (there's not a Xerox service center near here)? What does the part cost/where can I get it? Is it worth fixing, or should I just replace it for $200? Thanks--
  • 883 Answers
SOURCE: Engine Fuser Low Heat Error
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
Posted on Aug 28, 2007
rockfixya
  • 679 Answers
SOURCE: Ricoh FX16 open heat error
the Open Heat error indicates that the sensing circuitry for the fuser has detected that the fuser is not heating up. This can occur because either the sensing circuitry isn't detecting correctly or the fuser actually isn't heating up. Probably the latter in most cases.
How to fixya? Probably install a new fuser and you'll be fixed. Want to be sure before you spend $$ ?? Pull the fuser out. You will see a wiring hookup with two heavy wires that supply 110V to the heating lapm. Connect an ohm meter across the two wires that are on the FUSER. A good fuser will read around (0) ohms - complete circuit. A fuser with a bad lamp or a bad thermostat will read infinite resistance (open circuit).
The thermostat is probably available as a separate item. It's probably about $15 from several online sources. I believe you will need a JC47-00013A. I could be wrong. You'll need to do some research if you find that to be the problem.
Posted on Feb 09, 2009
  • 199 Answers
SOURCE: Xerox PE120 i dirty platen glass
there are only little plastic lock only, try with technician.
Posted on Feb 26, 2009
SOURCE: vista driver for xerox workcentre xd103f
Not available
Posted on Mar 21, 2009
SOURCE: open heat error
I think you can get a service/repair manual from this link:
http://www.nodevice.com/user_manual/samsung/printers/scx-4100.html
Posted on Jul 30, 2009
Need drivers for Windows 7 for my xerox workcentre pe120i
A Windows 7 driver is not available, but you may find that the Vista driver works OK. You can get it here:
http://www.support.xerox.com/support/workcentre-pe120-pe120i/downloads/enus.html?operatingSystem=winvista&fileLanguage=en
Feb 15, 2011 | Xerox WorkCenter PE120i All-In-One Laser...
Open Heat error on my xerox workcentre PE120 which I think I need to buy a fuse can you help
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 01, 2010 | Xerox WorkCentre PE120 All-In-One Laser...
Reads open heat error
This sounds like a problem with the fuser or possibly the fuser lamp. You can try turning the printer off for about ten minutes to cool the machine off and then turn back on. If that doesn't work you would need a new fuser unit. The fuser is located behind the door on right side of the machine. There are four screws used to hold the fuser in place. Good Luck, I hope this helps.
Aug 21, 2009 | Xerox WorkCentre M20i All-In-One Laser...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Workcentre M15i won't turn on after poss outlet short
turn it off
unplug it
wait a few minutes
plug back in
turn on
Feb 17, 2009 | Xerox WorkCentre M15i Laser Printer
Error code PCL6 incomplete session by time out
That is normally caused by firmware corruption. You can go to Xerox.com, click on support and drivers, then in the search box enter pe120, then go to drivers and downloads and download the newest machine firmware . There are directions on how to install the firmware , make sure you follow them step by step. It's pretty easy and should resolve your problem.
Feb 12, 2009 | Xerox WorkCentre PE120 All-In-One Laser...
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Workcentre pe 120i memory full
in spec. say's so:
your workcentre Pe120 have only 32 Mb memory.
fax function is equipped with a 4 Mb standard memory.
In spec. shows a 4mb memory is just enough for 320 pages of fax!!!
i think your problem is given from the 32 mb of memory of workcentre pe120, not from fax memory, because the faxes received or delayed is compressed with a very strong altgorithm, and these files is very small.
http://www.office.xerox.com/multifunction-printer/multifunction-under-30ppm/workcentre-pe120-pe120i/spec-enus.html#Memory
a link bellow ; i think is useful:
http://www.xeroxdirect.com/direct/public/products/accessorizer/dsp_accessory.cfm
for a 32 MB memory module (product code is: 097n01434)
Sep 23, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Jun 19, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Samsung SCX 4200 All-In-One Laser Printer Logo
106 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
