Question about Korg microKEY USB Powered Keyboard
My laptop (running Vista - 32 bit, SP 2) will not recognize my Korg Microkey. I have run the Vista driver for it with no luck. This problem just started this week, but when the computer did recognize it, I was only able to input a few notes in my Encore music notation software before the microkey would quit working.
2 Suggested Answers
  • 5603 Answers
SOURCE: KORG SP-250. Keyboard powers
There is probably a cable loose that connects the keyboard itself to the processor... OR the key contacts have been contaminated by spilled liquid. The keys are scanned as a matrix. The contacts will be a conductive rubber pressed against circuit board traces. Clean contact "pills" and the circuit traces with ONLY 99% isoprophyl alcohol.
This is NOT for the unskilled to attempt a DIY other than carefully opening and looking for a cable that has come loose.
Posted on Mar 22, 2011
Hou to reset to factory settings korg sp 200
You might search through the manual for the 20+ hits on the word RESET:
http://cdn.korg.com/us/support/download/files/e5fb7e3294b3843fc9633f45a0d23bef.pdf?response-content-disposition=inline%3Bfilename%2A%3DUTF-8%27%27SP200_EFGI1.pdf&response-content-type=application%2Fpdf%3B
May 12, 2018 | Korg Music
How to change a fuse on a korg Sp-250
There is no fuse inside SP250. If the unit can't power ON,there maybe damage to the adapter,adapter cord/connector,or broken fuse inside the adapter.
If adapter is in good condition, then the damage is inside SP250.
The possibilities are on regulator section.
Check all parts in this section (figure 1).
Also maybe there is a broken soldering joints at DC input socket.
change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-0.jpg change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-1.jpgchange-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-3.jpg
Jun 01, 2014 | Korg SP-250
IMPORTING FILES INTO THE KORG D3200
The import needs to happen from a computer (or a CD-RW) >D3200, not from a flash drive or backup drive.
Feb 12, 2014 | Korg D3200 Studio Package
Korg sp-250 randomly changes the voicing
When was the last time you changed the batteries? You may have gotten a pack of expired batteries the last time you replaced them. I suggest changing batteries.Jimmy
Apr 08, 2012 | Korg SP-250
KORG SP-250. Keyboard powers up, you can change all selections, five or six random notes sound, but the other keys produce no sound at all.
Mar 22, 2011 | Korg SP-250
I have a new Casio CTK 810 and installed driver and smf converter but cannot make a connection with my laptop and desktop, both Vista 32 bit........
Yeah, had that problem too with Vista (I used a 64bit) but it should work in Vista (32 bit) with limitations and Windows 7 32 bit
for Vista
http://support.casio.com/information.php?rgn=5&cid=008&pid=114
for 7
http://support.casio.com/information.php?rgn=5&cid=008&pid=934
Sep 29, 2010 | Casio CTK810 61 Key Keyboard
Korg PA800 not booting up
I suspect you have aa pwer supply problem that is supplying low voltage to the unit. The display will light at low voltage but circuitry will not run when voltage is low.
Jul 05, 2010 | Korg Pa800 Synthesizer
No sound
1. plug in some headphones into the jack.
2. connect to an amplifier or external source.
3. connect midi to a midi-compatible device and determine if device receives signal by pressing keys
If #1 or #2 passes, your speakers are bad.
If #1 & #2 fail, but #3 passes, your setting are set so that there is no sound, but the keybourd still recognizes input.
If all three fail, the keys do not send a signal at all, you should replace the keyboard.
Dec 19, 2008 | Korg Pa800 Synthesizer
Korg microKEY USB Powered Keyboard Logo
32 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Are you a Korg Music Expert? Answer questions, earn points and help others
