Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Samsung Model HCN4226W
I was told my 3 year old tv needs has a "bad yoke, picture tube and power supply problems" estimated repair $800. Is this something I can fix myself and if so can I get drawings, how-to and a list of where I can obtain the parts?
  • 3 more comments
  • dontec Aug 29, 2008
    My Samsung HCN 4226w is not powering up , the power light blink about ten times and then stop ..............Can anyone help me on this one ?
  • marvee Sep 07, 2008
    My 5 year old Samsung HCN4226W is not coming on (no picture and no sound). When pressing the "ON" button, I can hear a "click" like it wants to come on, but nothing happens. HELP!
  • poolman22 Sep 08, 2008
    first the sound went now it wont come on??
  • Anonymous Sep 19, 2008
    I just got a 42 inch rear projection from a friend but it has a hazy ghost blue ora and the letters are fuzzy. I am wondering how much it will cost to fix and is it damaging to continue to use it? Please help.
  • zinachka22 Nov 29, 2008
    hey ppl i have a powering problem when we called a tv repair guy he said something about a bulp being burnt out since it was my brother talking to him i didnt get much info repair would cost around 500$ but it is some bulp issue
I have done all you told me so for , the set still not working , any more idea what to do ?
Posted on Aug 28, 2008
  • Samsung Master
  • 8,617 Answers
Go to this site and leave a email with your model and what youre needing, they can help you out with the situation.
http://servicemanuals.vstore.ca/
Posted on Aug 25, 2008
OI HAVE A ZENITH H27H49S TV REPAIR MAN SAYS IT'S A SAMSUNG. TV HAS A POWER PROBLEM THE TV COMES ON NO PICTURE THUMBING SOUND. THE REPAIR GUY SAYS I NEED A YOKE SWIE2-0134 UNABLE TO FIND ONE. THE...
the yoke coil is very critical component of tv. it matches with the picture tube & the circuit. one can not replace with another kind of yoke. these yoke coils are very rare to get. i m so sad to say if it is not available you have to replace the whole tv.
Oct 08, 2011 | Zenith Televison & Video
After being on for about 30mins my Samsung Series 8 picture pixelates and sound drops out for a second or two, like it has lost the signal and this repeats every couple of mins after that, the TV is only...
Since unit is less than 1 year old, it would be covered under Samsungs warranty. Call 1-800-samsung and they will set you up for repair with an authorized service center. Your problem could be caused by a bad power supply board or a bad main board.
May 27, 2010 | Samsung LN46A650 46 in. LCD HDTV
My tv sumsung hcn4226w 42 inch rear projection will not turn on
either the lamp is burned out or the ballast and power supply board need to be replaced. can call 1-800-samsung for nearest service center.
Dec 11, 2009 | Samsung HCN4226W 42" Rear Projection...
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Hitachi 60" Ultravision TV - bad green tube that is leaking
If this has only started to leak recently, get an estimate from a local servicer for a coolant replacement for that tube. The coolant is corrosive and needs to be cleanedup ASAP from any circuit board that it has touched before there is damage. This is NOT a DIY repair. Expect a repair cost in the $300 range for parts and labor. If the set had a good picture prior to this, it may be worth the repair. This is your call. Do not delay however, as any delay will increase the likelyhood that there will be more damage that needs repair.
Dan
Dec 09, 2009 | Hitachi Televison & Video
Samsung TXN203F displaying only blue and green
Well, it depends, it is one of three possible issues, 1. bad video driver on the crt board, 2. Bad Picture tube 3. Bad video processer.
Most lkely is either 1 or 2 above. If it is no 1. the repair would be reasonable probably around 90-100 dollars. Video processer is not likely but can be the issue.
Oct 10, 2009 | Samsung TXN2034F 20" TV
Convergence problem on my Samsung 42'' model hcn4226w
Yes, your diagnosis is correct, convergence board is bad and needs to be replaced in TV.
Aug 19, 2009 | Samsung Televison & Video
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
Samsung 55" TV does not turn on
CHECK YOUR RED ,GREEN AND BLUE CRT'S THERE MAY BE A SMALL CRACK ON THEM.MAKE SURE TO TAKE THE YOKE OFF AND INSPECT THE ENTIRE TUBE IF THER IS A CRACK IT IS CAUSING YOUR TV TO GO INTO SAFE MODE. ALSO CHECK THAT NONE OF THE COOLING FLUID HAS DRAINED OUT OF THE TUBES ON TO THE CRT BOARDS IF SO REPLACE THE BOARDS AND CRT IF CRACKED. YOU CAN FIND ALL THE PARTS AT PARTSTORE.COM HOPE THIS HELPS.
Sep 04, 2007 | Samsung HCN5529W 55" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Henry  Thomas
Henry Thomas
