Question about Canon PowerShot A75 Digital Camera
How do you get the case apart?
I have removed the 5 screws outside the case, 2 inside the CF compartment and 2 in the batery compartment. I removed the zoom and the case is loose at the bottom but something seems to be holding it at the top in the area of the mode selector.
Thanks for any help.
  • GRICHARD Sep 02, 2008
    This documentation is very detailed and just what I needed. Thanks.
  • GRICHARD Jan 13, 2009
    Thanks. Very helpful
  • Canon Master
  • 4,738 Answers
You have to remove the shutter button assembly first. Please see the following for a similar A70:
http://www.thustra.com/A70mod/
Posted on Aug 30, 2008
HOW CAN I OPEN UP A REMOTE CONTROL UNIT / MAGNAVOX - NC003UD TO CLEAN IT
Check inside the battery compartment and feel over any labels, there may be screws there that need to be removed before it will come apart. If no screws then there will be snap clips around the outer edges of the case, but inside so you don't know exactly where they are located. To get it apart use something like a credit card push it in between the 2 halves of the housing and slowly work it around, in and out until you find where the snaps are located, then use the card to carefully slide the snaps apart. Good luck...the snaps do tend to breal easily.
Aug 13, 2014 | Magnavox NC003 Remote Control NC003UD
Cf-29 replace mouse pad
Panasonic Toughbook CF-29 series of Notebook PC's, Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-panasonic
Go to the line that starts with CF-29N3LGZBM, and CF-29NTQGZBM
For the CF-29N3LGZBM the disassembly starts on Page 19, and for the CF-29NTQGZBM.
I don't see the difference, but perhaps you will between the two.
To me a CF-29 is a CF-29
You disassemble from the Bottom up. Remove Base Enclosure,
http://www.youtube.com/watch?v=-ITIcLckkIw
(No narration, just 'elevator' music)
Remove Mousepad,
http://www.youtube.com/watch?NR=1&v=8BJRwBwCKhg&feature=endscreen
A) Remove ALL power. Remove the AC adapter (Charger), and Battery
B) USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
(Electro Static Discharge)
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Wear an ESD wrist strap, and your laptop is safe from Static.
(From you)
Don't wear one, and use your laptop for an expensive paperweight.
Average cost is $3 to $6. This is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of an empty open desktop computer case. (I don't feel an Anti-Static Mat is warranted, and can explain)
You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or perhaps a large metal knickknack. (Unpainted)
You can't discharge Static by touching the metal frame, of the laptop.
Doesn't work that way. (ZZZZZzzzzap! Goodbye computer )
C) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws!
Advise do NOT mix them up.
D) Take photos, or use a video cam; if available. Use good lighting.
Make notes, and/or drawings if you wish.
It's nice to have a Personal record, as well as a Service Manual, and pictorial information.
It's nicer to have YOUR method YOU used, along with the above.
Jus sayin'.
No.1 Philips screwdriver
Put everything back just LIKE it came out. Don't pinch any cables.
http://www.bobjohnson.com/_store/Display_Buy.asp?prodID=CF29MOUSEBOARD
http://www.ebay.com/itm/Panasonic-Toughbook-CF-28-Touchpad-Palmrest-/290787254286?pt=LH_DefaultDomain_0&hash=item43b445600e
http://www.ebay.com/sch/sis.html?_nkw=Panasonic%20Toughbook%20CF%2029%20Pentium%20M%201%2030Ghz%20512%20MB&_itemId=151000412795
Wow! Sellin' kinda cheap! Looking for parts I ran into this.
Not advertising. Besides, it isn't allowed on here anyway, lol!
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Panasonic Toughbook CF-29 Notebook
How do I replace my keyboard on a CF-52
For the Panasonic ToughBook CF-52 series of Notebook PC's, it's a little tougher to remove the Keyboard, than per se other models.
1) With all repair on laptops first remove ALL power.
Remove the AC adapter (Charger), and Battery.
2) Next you should follow Anti-Static Precautions. A little more on this as to why as you read, but you'll also see you will be very near the Processor.
A Processor is the most susceptible hardware component in a computer, to Static shock.
(It's close to the Keyboard Lid Plate under the Keyboard)
Anti-Static Precautions:
Static can fry out (Short Circuit) the delicate hardware components inside a computer.
The best method is to buy, and wear an ESD wrist strap, and connect it's alligator clip to a good ground source. (Electro Static Discharge. About $5)
The next best method (Debatable) is to place a large metal object on the table, and touch it before disassembling the laptop, and occasionally during.
(Metal serving dish, metal knickknack, etc.)
3) Components to be removed in order; [Straight from the Service Manual]
A) Power, as mentioned
B) The HarDDrive and it's mounting kit.
C) The DVD optical drive
D) The Tilt Panel Assembly
Simply the top outer cover along with the LCD screen that is mounted to it.
The part you tilt up and look at.
E) Keyboard Lid Cover
F) Keyboard
4) Use a multi-compartment container for the various screws you will remove. Mark each container for the area the screw/s come out of.
DO NOT mix them up!
[Some screws look very similar to other screws, plus they are S-M-A-L-L.
Put a screw in the wrong hole, and it may seize halfway in.
Cannot remove it without damaging the laptop, and cannot screw it all the way in.
You can substitute using a multi-compartment container, and use a clean egg carton instead.
Label each egg holder]
Make drawings, and notes if you wish. A guide to return to in case you are interrupted.
5) This is a link to the Service Manual for the Panasonic ToughBook CF-52 series of Notebook PC's.
It is for a CF-52EKMxDxM, but will work for all CF-52 series models, (Manual is free),
Page 24 for the Disassembly Flowchart
Page 25 for removing the HarDDrive, and it's mounting kit, plus the DVD optical drive.
Page 26 for the Tilt Panel Assembly
Page 29 for removing the Keyboard Lid Plate, and Keyboard.
I'm here for additional questions please post in a Comment.
Regards,
joecoolvette
Jun 21, 2011 | Panasonic ToughBook 52 Notebook
I have a franklin sa-309 and I do not now how to remove the red tag on the right side.
The red tag is most likely the end of a cloth strap used to help the user remove the (2) AAA batteries
from the Franklin SA309 Spelling Ace Pro & Puzzle Solver. To store the red tag back inside the
uit, you'll need a #1 phillips screwdriver (the "regular" size phillips screwdriver is a #2, so the #1 is
a bit smaller).
To access the batery compartment, turn the unit over, and unscrew the screw holding the
battery compartment closed. Then push the red tag inside (flattened to the batteries), and
re-install the battery cover screw.
Here's the 24-page online users manual for your device (PDF file):
http://www.franklin.com/manuals/sa-309.pdf
Consult pages 4-5 for battery replacement.
May 29, 2011 | Computers & Internet
My phone sony erissson c902 can't sent msg
Instructions
things you'll need:
* Phillips-head screwdriver
* Torx T6 screwdriver
* Credit card
Hold down the phone's power button until it shuts off. Place the phone so the back side is facing upward. Remove the back cover and remove battery pack from its compartment inside the phone. Slide the SIM card out of its slot inside the battery compartment. Set it aside.2
Loosen all screws from the phone's back casing. Depending on your exact phone this will include either Phillips or Torx T6 screws. Remove the back casing to reveal the internal circuit board.
* 3
Remove all screws fastening the circuit board to the phone's casing. Unplug all ribbon cables from the visible side of the circuit board. Lift the circuit board out of the phone's front housing and unplug the the ribbon cables from the opposite side of the circuit board. This disconnects the keypad and LCD screen from the circuit board. Remove the board from the phone's casing completely.
* 4
Flip the phone over, and insert a guitar pick or credit card into the gap along the outside edge of the phone's front housing. Use the pick to pry the front housing from the phone to reveal the keypad and LCD screen. Remove the two to four screws fastening the keypad to the phone's frame. Lift the keypad out of the phone and set it aside.
* 5Use the guitar pick to gently pry the LCD screen out of the phone's frame. Set it aside.
Apr 23, 2011 | Sony Ericsson Cell Phones
Is there a trick to getting to the rear turn signal on a 2003 ford focus hatchback. I had removed the screw to the lens cover but I still cannot gain access to the turn signal bulb to replace it.
Replacing tail/brake/backup lights and turn signal bulbs (coupe)
1. Make sure the headlamp control
is in the OFF position and then
open the hatchback.
2. From inside the luggage
compartment remove the wing nut
of the rear light assembly cover.
3. Using a Phillips screw driver
remove the screw. The lamp is still
retained by a spring loaded clip.
Remove by gently pulling out the
light housing.
4. Turn the bulb socket counterclockwise as far as possible and pull it
out.
5. Pull the bulb straight out of the socket.
Install in reverse order.
Replacing tail/brake/backup lights and turn signal bulbs (sedan)
open the trunk.
compartment remove the three wing
nuts of the light housing.
3. Gently pull the light housing to
the outside.
counterclockwise and pull it out.
Replacing tail/brake/backup lights and turn signal bulbs (wagon)
open the hatchback.
2. Using a screw driver remove the
fixings and trim from the body.
3. Remove the socket from the lamp
assembly
4. Pull the bulb straight out of the
socket.
Hope this helps.
Zeppelinx12
Mar 03, 2011 | 2003 Ford Focus
Is the heater core on a 1981 bronco in the engine compartment or the cab compartment
in the cab, but procedures are different depending on whether or not you have A/C. See below
1980-81 Comfort Vent Heaters, Without Air Conditioning
  1. Disconnect the heater hoses from the heater core tubes and plug the hoses with suitable 5 / 8 inch; (16mm) plugs.
  2. Remove the glove compartment liner.
  3. Remove two (2) spring clips attaching the heater core cover to the plenum along the top edge of the heater core cover.
  4. Remove eight (8) screws attaching the heater core cover to the plenum and remove the cover.
  5. Remove the heater core from the plenum taking care not to spill coolant from the core.
To install:
  1. Install the heater core in the plenum.
  2. Install the heater core cover (eight (8) screws and two (2) spring clips along the top edge of the cover).
  3. Install the glove compartment liner.
  4. Connect the heater hoses to the heater core. Tighten the hose clamps.
  5. Add coolant to raise the coolant level to specification.
  6. Check the system for proper operation and for coolant leaks.
1980-81 Standard & High Output Heaters, Without Air Conditioning
  1. Disconnect the temperature cable from the temperature blend door and the mounting bracket on top of the heater case.
  2. Disconnect the wires from the blower motor resistor and the blower motor.
  3. Disconnect the heater hoses from the heater core and plug the hoses with suitable 5 / 8 inch; (16mm) plugs.
  4. Working under the instrument panel, remove two (2) nuts retaining the left end of the heater case and the right end of the plenum to the dash panel.
  5. In the engine compartment, remove one (1) screw attaching the top center of the heater case to the dash panel.
  6. Remove two (2) screws attaching the right end of the heater case to the dash panel, and remove the heater case from the vehicle.
  7. Remove nine (9) screws and one (1) bolt and nut attaching the heater housing plate to the heater case, and remove the heater housing plate.
  8. Remove three (3) screws attaching the heater core frame to the heater case and remove the frame.
  9. Remove the heater core and seal from the heater case.
To install:
  1. Position the heater core and seal in the heater case.
  2. Install the heater core frame (3 screws).
  3. Position the heater housing plate on the heater case and install the nine (9) screws and one (1) bolt and nut.
  4. Position the heater case to the dash panel and install the three (3) attaching screws.
  5. Working in the passenger compartment, install two (2) nuts to retain the heater case and plenum right end to the dash panel.
  6. Connect the heater hoses to the heater core. Tighten the hose clamps.
  7. Connect the wires to the blower motor resistor assembly.
  8. Connect the blower motor wires.
  9. Position (slide) the self-adjusting clip on the temperature cable to a position approximately one 1 inch; (25.4mm) from the cable end loop.
  10. Snap the temperature cable on the cable mounting bracket of the heater case. Then, position the self-adjusting clip on the door crank arm.
  11. Adjust the temperature cable.
  12. Check the system for proper operation.
Oct 05, 2010 | 1981 Ford Bronco
How to replace latch
The latch is incorporated into the palm rest which you can buy on Ebay for around 25 bucks.
The simplist way to do this is to remove all the bottom case panels to make sure there are no hidden screw holes. Remove the connectors on the wireless card, remove the battery and the three black screws inside the battery compartment. Remove the screw and the dvd drive. Remove all the screws from the bottom case. Turn the laptop back over and remove the power button cover, start prying the cover up on the right side, it will come off as long as you removed the three screws from the battery compartment. Once the cover is off, press on the small indentions around the edge of the keyboard, this will release the keyboard. Release the keyboard cable clipand remove the keyboard. Unplug all the cables from the motherboard and unplug all the flat cables from the palmrest to the motherboard. There are several screws holding the palmrest to the bottom case assembly. Remove these screws and note their location. Once the screws have been removed, start working the palmrest free from the bottom case half, if all screws have been removed will pop apart, lift it from the back and tilt it toward the front and lift the palmrest away.
Mar 30, 2010 | Acer Aspire 5315 Notebook
I am trying to change the lcd screen
if it is a 1001 all you need to unscrew is 4 screws on back black ones you will need to remove warrenty sticker inside battery compartment and then remove screw on trim ring. with 2001 remove 4 screws 2 under batery as above one is covered by warrenty sticker then remove one screw on bottom of trim then 2 small screws by usb use small flat head screw drive to release screen from screen mount
May 22, 2009 | Sony PlayStation Portable (PSP) Console
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
