Question about Olympus Camedia C-720 Ultra Zoom Digital Camera
Changing the quality setting
How does changing the quality setting in a shooting mode affect other shooting modes?
    Master:
  • 852 Answers
There are three groupings of shooting modes on the C-720UZ - 1) Program & A/S/M, 2) Auto & Sports & Portrait & Landscape, 3) Movie mode. Each group can retain a quality selection for all modes in the group. Therefore, you cannot have a different quality setting for each shooting mode within a grouping.
Posted on Sep 04, 2005
SOURCE:
SB-900 flash problem
Set the flash to shoot/fire in the Auto Flash modes.
So what is it, a SB-80dx or SB-900?
atdleeatnetzerodotcom
Nov 06, 2013 | Nikon Speedlight SB-80DX TTL Flash
Tip
How does aperture setting affect a photograph?
The aperture is the opening in the lens through which light passes to the image sensor. Changing the aperture setting allows you to control the depth of field of a photograph. When the aperture is opened to a widersetting, (indicated by a lower f-stop number) more light is passed to the imagesensor, creating more shallow depth of field. Closing the aperture (indicatedby a higher f-stop number) allows less light to pass to the image sensor,creating wider depth of field.
NOTE: The aperture setting is one of three primary settings usedto control the overall exposure of a photograph. The other two primary settingsare ISO and shutter speed. Because the three settings work together to produce the overall exposure for a photograph, changingthe aperture setting will require complimentary changes to either the ISO or shutter speed to produce a properly exposed photograph. These changes will bemade automatically by the camera in the Auto, Program, Aperture-priority andShutter-priority modes.
There are two ways tocontrol the aperture setting on the camera:
  • Aperture-priority mode (A) - When shooting in Aperture priority mode (A), you set the aperture value and the camera automatically sets the optimum shutter speed for you.
  • Manual mode (M) - When shooting in Manual mode (M), you control both aperture and shutter speed, which gives you maximum creative control to achieve the exact results you want.
on Jan 08, 2011 | Cameras
Set aperture
Unfortunately, as with most point&shoot cameras, you don't get much control over the aperture. The camera is intended for you to point and shoot, without bothering about such details.
You can get some control by changing the shooting mode. For example, the Landscape mode will attempt to close down the aperture in order to deepen the depth of field, while the Portrait mode attempts to open up the aperture to narrow the depth of field.
This is one of the things that separate point&shoot cameras from more sophisticated (and more expensive) cameras.
Sep 22, 2013 | HP Photosmart M547 Digital Camera
Changing shutter speed
Like many point&shoot cameras the JZ300 doesn't give you direct control over the shutter speed; you're expected to just point and shoot.
You can indirectly affect the shutter speed by changing scene modes. For example the sports mode will try to use faster shutter speeds while the landscape mode will narrow the aperture for greater depth of field resulting in a slower shutter speed.
Mar 03, 2013 | FUJIFILM FinePix JZ300 Digital Camera
The camera is set on Auto. The pictures are a blur, not in focus. Is there a way to set up good focus?
Revie manual here:
User Guide.pdf
This your camera:
Nikon Coolpix 775
1.check your lens camera is clean and clear.
You have to choices, auto and scene.
What happen when you choose scene mode?
2. test change your image quality to normal. you can go to menu even in shooting mode.
3.change image to normal and back to shooting mode and try again
It is same ?blur?
4.if still blur, try go to menu mode again, at left side you can find BSS.
5 IF BSS is off.. change it on. if it is on, change it off.
6.go to shooting mode again.
that all. good luck and rate me..tq
May 12, 2011 | Nikon Coolpix 775 Digital Camera
How do I change the shuuter speed on my A550 power shot canon camera
Since there is no shutter or aperture priority mode on the A550, the shutter speed is predetermined by the shooting mode. You can try changing the ISO speed when in a certain mode, but the camera may compensate by changing the aperture setting rather than the shutter speed. You'll have to experiment.
You can place the camera in Long Shutter Mode, however, when you want exposures times between 1 and 15 seconds. You set that by pressing the Function menu and Func. Set button when in [Camera icon]M mode, then using the < and > buttons to cycle through the long shutter settings.
Hope this helps!
Mar 10, 2011 | Canon PowerShot A550 Digital Camera
My flash simply will not work. I have a hard time getting a photo when the flash is needed because it won't allow me to shoot. I select 'no flash' and I get a photo but poor quality. Thank you!
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies When shooting in the Twilight or Handheld Twilight mode If shooting with the Burst or Multi Burst mode Shooting with Sweep Panorama mode Shooting with the Fireworks or High Sensitivity mode. If an external flash is connected. Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
If the issue persists, please reset the Camera and make sure that battery is fully charged. If the issue persists after performing all the above mentioned troubleshooting steps, service is required. If you feel that the above Troubleshooting steps, helped you. please rate my answer positively. Thanks for understanding.
Jan 18, 2011 | Canon PowerShot A560 Digital Camera
Sony dcr hc30
I wish to transfer my DCR-TRV480 NTSC video to my PC. I have set my camera to Play/Edit mode. However, when I insert my USB cable into my video camera, the message "Disconnect the USB cable before changing the setting" appears, preventing me from playing/transfering my video. What can I do?
Apr 11, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
There are three groupings of shooting modes on the C-725 UZ: 1) Program & A/S/M, 2) Auto & Sports & Portrait & Landscape, 3) Movie mode. Each group can retain a quality selection for all modes in the group. Therefore, you cannot have a different quality setting for each shooting mode within a grouping.
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
Cannot set "HI" Mode to shoot TIFF Images
In order to shoot "HI" TIFF images first set the Image Size option to either "5M 2592x1944" or "3:2 2592x1728." Next, choose "HI" as the Image Quality option. "HI" is only available in one of the manual exposure modes (P, S, A or M) and is not available in the "Auto" shooting mode. If "HI" is selected and the camera is switched to "Auto" the Image Quality will automatically switch to "FINE" mode and a JPEG image will be recorded. Additionally, "HI" is only available in "S" Single frame Continuous shooting.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Olympus Camedia C-720 Ultra Zoom Digital Camera Logo
99 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
