Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Saeco royal when i make a coffee the process is so slow it drips the coffee out not pours it out. is this normal. cause before it used to go much faster and pour the coffee out. not drips
  • 515 Answers
Try to set the grinder to grind coarser, make 2-3 cup of coffee to get coffee with the new settings.
/Mirran
Posted on Aug 27, 2008
My Seaco Royal Machine has got double problems. The first one is; water dripping from the bottom to the floor. The second is; coffee coming out slowly (drops ). The second is; the sounds that accompany the...
The leak may be due to a clogged weep passage that resides behind the brew group and empties into the drip tray in the front. Take a long piece of wire or a good paperclip and straighten it out. Take some hot soapy water and a small syringe and wash that area out with the drip tray installed. As for the coffee coming out too slowly, you may want to adjust the grinder to a more coarse grind by one or two clicks. After each single adjustment to the grinder, it will take two brew cycles to catch up to the adjustment. Don't make too many adjustments without running at least two cycles in between each adjustment. If that does not solve the problem, you may need to take it to the repair center nearest you to have them check out the pump.
Feb 03, 2014 | Saeco Royal Professional Espresso Machine
Hello, I have a Saeco Royal Digital Plus. I have a problem with water getting into the little tray under the brew. (Normally there will be little coffee residue in the tray). While doing the thin coffee....
This a normal operation. As much fine is the coffee grinding is set then the water make it more difficult to pass through and when the coffee process finish the water remains in the piping sytem after pressure lelease in the try under brew group. All you need to take care is that the grinding is not adjusted too fine thus runnig very slow and coffee will be burned and become bitter. Also you need to remove the brew group very often and clean it with warm water and every month remove the st. steel filter from brew and clean it so all holes are open from dry coffee. You can also use the special coffee cleaning tablets to perform a cleaning proccess so the machine remains in good shape. You can find all these informations, parts and others about your machine at the http://www.partsguru.com/SaecoRoyalDigital.html
Jul 17, 2011 | Saeco Royal Digital Plus Coffee...
How to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Jun 13, 2010 | Saeco Royal Digital Plus Coffee...
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
Problem with Saeco royal digital plus
Try replacing the O ring in the brew unit
Oct 27, 2008 | Saeco Royal Digital Plus Coffee...
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Drip Tray and Container for coffee stuck
the only thing would our drip tray is not properlt install and is jamming the rest try to move in and out the drip tray i am sure you already try it but it about the only thing that can hold the rest take our time dont force it good luck cheers
Jan 20, 2008 | Saeco Royal Exclusive 30153 Espresso...
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
336 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
