Question about RIM BlackBerry Pearl Smartphone
Medoa card blackberry pearl....media card ahs an error? and it says its unreadable?? and how do i format the card??
    New Friend:
  • 117 Answers
1. Press Blackberry Button
2. Go into Options
3. Go into Advanced options
4. Select Media Card
5. Press Blackberry Button
6. Select Format Card
If this does not work, get hold of a MicroSD to USB convertor put into PC and format that way.
Useful program:
Please go to the site below:
http://www.sdcard.org/about/downloads/
SD Formatter Ver2.0[2.0.0.3] exe file (1.315Mb)
Install the program in your computer, then insert the card into the card reader (if you do not have reader, you can try to connect your device to the computer with USB cable) and then run it:
a. Check the drive letter and also the size and make sure it is the correct card.
b. Click Option:
Format Type: Full Erase ON
Format Size Adjustment: ON
c. Click OK, then click Format. Wait until it finish.
d. You will be prompted to remove the card after it finish.
Hope this helps
Gadget
Posted on Sep 01, 2008
Can't see files located on the 4gb micro sd hc memory card on my Blackberry 8100 Pearl. Path:Media/Music/Media Card - the folder comes up blank. Any ideas?
your card may not work with the blackberry. try formatting the card via it ebeing in the blackberry, and then put everything back on the card afterwards. it should work. if not again, your card might just not be compatible wit the phone
Feb 17, 2010 | RIM BlackBerry Pearl 8100
When i put my media card in my blackberry it says its not there?
back up first all of your files.then format your media card using your Blackberry,not your PC.If it is still same problem after formatting,try to replace another media card and check if other media is working in your phone.lastly,if still not working its already a hardware problem,its a memory card IC,not working anymore,you must replace it.
Jul 22, 2009 | RIM BlackBerry Pearl 8100
Blackberry Disk no longer works. need disk error checking utiliy
your best bet is to format the media card. just insert it into a computer and then right click the drive that is assigned to it and format it. be forewarned that this will erase all of the data on your card!
Jul 11, 2009 | RIM BlackBerry Pearl 8100
My blackberry says i need to format my media card and when i do the phone freezes
take the battery out and put it back in and see if you still get the error on your card
Jun 06, 2009 | RIM BlackBerry Pearl 8100
Video camer
I was unable to change the file format in which the camera on my phone records, but... unfortunately, I formated my media card, and it works fine now, yes, I erased everything I had on there, but.. I have since reloaded everything I had backed up on my p.c. and commenced recording video's and it works!!!
thank you
Feb 27, 2009 | RIM BlackBerry Pearl 8100
Can't open data stored on media card
Connect the BlackBerry to your computer.
Open My Computer, and open Properties of the drive.
What does it show under File System?
The BlackBerry cannot read NTFS, so make sure that it is not an NTFS file system. if it is, move your files off the card, and format it as FAT, then put the files back on the card after the format.
Otherwise, without the BlackBerry connected to the computer, go to Options (or Setting > Options, depending on your Theme),
Then opem Media Card, or Memory (depending on your Theme and software version).
What does it say about the card? Does it say that it is connected, or that there is no card?
Jan 21, 2009 | RIM BlackBerry Pearl 8100
MY MEDIA CARD!!!
if the phone works properly without the card,you will possibly have to format it on your computer.
would you plz tell me what happens when the card is not i n the phone?
Oct 24, 2008 | RIM BlackBerry Pearl 8100
Media card
jus put ur card in card reader and format it it will start working
Jun 19, 2008 | RIM BlackBerry Pearl 8100
My media card
How to view or access media files on the microSD memory card - Mini Secure Digital (miniSD) Memory Card RIM BlackBerry Pearl 8100
To view or access media files on the microSD memory card, follow these steps:
  1. From the Home screen, press the Menu key.
  2. Scroll to and select Media.
    • NOTE: To select, press the trackball.
  3. Scroll to and select one of the following folders:
    • Music
    • Video
    • Ringtones
    • Pictures
  4. Scroll to and select Media Card.
NOTE: If the files transferred to the microSD memory card (media card) are not visible, turn on mass storage for the media card:
To turn on or turn off mass storage for the media card, follow these steps:
NOTE: If you receive the error message 'enable mass storage' on the handheld, follow the steps below.
  2. Scroll to and select Options.
  3. Scroll to and select Advanced Options.
  5. Scroll to and selelct Mass Storage Support.
  6. Select On or Off.
  7. Press the red End key to return to the Home screen.
NOTE: If the memory card is unreadable, you may need to format the memory card.
If you have anymore questions just ask me.
Apr 23, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Pearl Smartphone Logo
61 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
