Question about Olympus Camedia C-720 Ultra Zoom Digital Camera
Terminal for an external flash
Does the camera have a terminal for an external flash?
    Master:
  • 852 Answers
No, there is no terminal for an external flash on the C-720 Ultra Zoom.
Posted on Sep 04, 2005
SOURCE:
What dose it mean when engin light falshes contstantly
Flashing Diag Code P0122
TP circuit low input
DETECTION CONDITION
• If PCM detects TP sensor voltage at PCM terminal 89 below 0.10 V after engine start, PCM determines
that TP circuit has a malfunction.
POSSIBLE CAUSE
• TP sensor malfunction
• Connector or terminal malfunction
• Open circuit between TP sensor terminal C and PCM terminal 89
• Short to ground circuit between TP sensor terminal C and PCM terminal 89
• Open circuit between TP sensor terminal A and PCM terminal 90
• Short to ground circuit between TP sensor terminal A and PCM terminal 90
• PCM malfunction
Flashing Diag Code P0123
TP circuit high input
DETECTION CONDITION
• If PCM detects TP sensor voltage at PCM terminal 89 is above 4.77 V after engine start, PCM determines
POSSIBLE CAUSE
• Open circuit between TP sensor terminal B and PCM terminal 91
• Short to reference voltage (Vref) supply circuit between TP sensor terminal C and PCM terminal 89
• PCM malfunction
Jun 26, 2014 | 2000 Mazda Protege
Where can I get 10pin terminal and flash sync terminal covers for a Nikon D200
you get your things from here click the below link
http://cgi.ebay.com/Nikon-Flash-Sync-+-10-pin-caps-for-D200%2FD2Xs%2FD2X%2FD2H%2FD1_W0QQitemZ250501628194QQcmdZViewItemQQimsxZ20090921?IMSfp=TL090921165005r23188
Sep 22, 2009 | Nikon D200 Body Only Digital Camera
Vivitar 283 won't flash, exept through pc terminal
Hi if it is a Japanese 283, CAREFUL, you are working with ~300V
remove the sensor from the front. Short out the terminals at 7 o'clock and 11 o'clock with eg a paper clip, and then charge up the flash . Short the centre terminal with the one at 7 o'clock. If the flash fires, then it probably needs a replacement hot shoe from ebay. If it doesn't, it is a simple job to fix for an electronics worker. Manuals are available on ebay.
I repeat, careful with the Japanese flashes, you will have ~300 volts near you fingers, so if you are less than 100% confident that you won't blow the top of a finger (or worse), get an electronics worker to look at it.
Don't use the ebay hot shoes on a 300 volt flash, you will have the 300 volts out in the open and ready to bite you - have a look how well hidden the second contact is on the Vivitar plastic hot shoe.
Good luck the Feral Photographer
Dec 14, 2008 | Vivitar 283 Flash
Casio exilim z-75 bettery charger
Use a PP3 battery. Get 2 pieces of thin wire. and strip off about 2Cm from one end on each wire and about 5mm on the other. Wrap the 2cm stripped end of. one of the wires around the smooth round post on the battery (the + terminal) and twist it round tight so it is secure. Carry out the same with the other piece of wire to the Castle connector on the battery (the - terminal). Touch the lead from the + terminal on the PP3 to the terminal that is marked + on the exilim battery, and do the same with the lead from the - terminal on the PP3 to the terminal that is marked - on the exilim battery (don't worry about the terminal marked T on the exilim battery. Hold the wires onto the Exilim battery for about 30 seconds and then put the battery into the charger as normal and it should work. Don't forget to take the wires off the PP3 when finished.
Dec 10, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Polaroid i630 camera keeps shutting off
I dont know what is wrong but I have the exact same problem with mine!!!!
May 25, 2008 | Polaroid PhotoMax PDC 4055 Digital Camera
Does the DiMAGE A1 support any external flash including studio light?
Yes, it does. It is usable with any external flash using sync cord to sync terminal. (sync voltage: below 400V, correspond to antipolarity)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Yes, there is a 5-pin external flash terminal on the C-730 Ultra Zoom.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
No, there is no terminal for an external flash on the C-725 Ultra Zoom.
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
Extension Flash connector terminal
You would use the Extension Flash connector terminal along with the optional flash bracket "FL-BK01" and bracket cable "FL-CB01" so that you can use the Olympus FL-40 dedicated flash. With the use of bracket cable "FL-CB04", you can use another brand extension flash.
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Olympus Camedia C-720 Ultra Zoom Digital Camera Logo
81 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
