Question about Samsung HCM653W 65" Rear Projection Television
Samsung HCM653W Bulbs looks ok, because you can see all three colors on the screen in sample. Is convergens board is part of main board ? Thanks.
  • Samsung Master
  • 5,138 Answers
Convergence board will have 2 big black ics on it STK392-110s or 150s Use number on STK s in your set.To get parts call 1-800-223-3205 Electronix Parts.
Posted on Dec 22, 2008
My samsung plasma PN60E550 lost resolution and screen is fuzzy and has incorrect colors.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 26, 2016 | Samsung PN60E550 60 1080p 3D Plasma HDTV
Samsung HCM653W 65 in rear projection tv
its the convergence board/bulb problem for sure.check that and replace it.every thing will be fine.thanks.
Aug 22, 2008 | Samsung HCM653W 65" Rear Projection...
How can i adjust colors in konica c450
HI ganesh,
Instructions
    • 1Go to the Application screen on the LCD panel located on the printer and press on "Edit Color." Press on "Color Adjustment."
    • 2 If unhappy with the hue of your copy, press "hue." Look at the 'hue" screen and press the arrow keys in the direction you wish to change the color hue. Press "Sample Copy".
    • Sponsored Links
    • 3 Take a sheet of paper and place in the top left corner of the glass surface of the Bizhub. You will see that the area is marked "Sample Area" alongside the glass area. Press the "Start" button on top of the Bizhub.
    • 4 Wait for the Bizhub to produce a sample sheet. Look at the finished sample sheet -- there are six options showing three incremental "plus" hue options and the three incremental "negative" hue options. Select the one you like and press to confirm the required hue adjustment on the "Hue" screen. You have now calibrated your colors as desired.
Read more: http://www.ehow.com/how_7590176_calibrate-colors-konica-bizhub.html#ixzz316wHLgOK
May 08, 2014 | Office Equipment & Supplies
Look like the image is divide on three.red,blue,green .yesterday was normal.my son finish video game and turn off.Today I turn on and the image cannot show all colors together.
this is a normal problum pls. check remot cantrol on menu key press then selact convergen seting see on the screen canter three cross line arrow to set UP / DW/ LIFT/ RIGHT key maeching 3 line and see cross line is White then see the pictuer is ok
if not working convergen seting then spare STK replace in inside your tv set
Oct 29, 2009 | Sony KP-61HS30 TV
HCM653W color convergence off
Ck low ohm resistors 3.9 omh and pico fuses they look like resistors but they are green or yellow 5amps, 6amps,sometimes after replacing STKs there is bad resistors or open pico fuses.
Dec 22, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W Convergence problem
CK low ohm resistors and pico fuses some are green,some are yellow .they will be around ics some may be under heat sinks that hold STKs.
Nov 29, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W 65 in. Television
Dear,
I do not know, what the problem you have in your tv M/N:HCM653W. I have the same Model samsung tv. I have image ghosting problems. As per tech I replaced the Pcb,sub.samsung part AA95-01846D, Which did not fix the problem. I still have it for sale. The power supply pcb is no longer availabe as per"Partsstore.com. I have no idea where you can find the power supply board. If you find it,please let me know.
Thanks.
DollarTech
Jun 18, 2008 | Samsung HCM653W 65" Rear Projection...
RGB COLOR PROBLEM.
You will need to check the plus and the minus convergence voltages in the main power supply. There are a couple of circuit protector fuses that go bad. Do not replace these untill you replace the convergence IC's or you will cause more problems in the main power supply. Good Luck
Apr 22, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W 65" Rear Projection Television Logo
123 people viewed this question
Jerry Greenberg
Jerry Greenberg
