Question about Cobra 19 DX IV CB Radio
Need more power
Ok i put the cb in my 01 jeep wrangler, ive had problems with noise interference but got most of that fixed, i have a fiberglass k40 antenna, hot wire directly to battery, grouded to body, but the problem is i can pick up pretty well its i cant go out that far, any quik inexpensive fixes for giveing me more output power, i had a guy tell me i could snip something on the circuit board and it would fix the restrictor they have on them, im not really firmiliar with cbs anyway just thought it would be something fun to get into, and dont want to pour a bunch of money into it, any ideas on a cheap fix
Cbtricks.com
Posted on Sep 15, 2008
Just purchased a new galaxy dx959. Coax and k40 10k watt antenna. Installed it in my peterbilt 379. I have a lot of background noise. I tried unhooking the coax from back of radio and the noise goes...
You probably have the 959 that has a MOSFET final. It is not recommended that you try to get more power/mod by just turning pots. This can shorten the life of the MOSFET drastically. I normally set the power output to 7 watts and the mod to 100%. This give around 30 watts peak on AM and around 25-30 watts sideband. You need proper test equipment to align the radio.
As far as background noise, this type of radio does have more that others. Make sure the Noise blanker and ANL are turned on. If you are getting noise from equipment in the vehicle, you should take your truck to a good CB shop. They can find out what is causing the noise and fix it.
....Don at NTCB, Inc.
Jun 08, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Ok so when I bought my '97 jeep wrangler a couple of months ago it came with a CB. It is all hooked up, came with a huge antenna( 4-5ft maybe), all of the lights come on, the weatherman channel works, and...
check the sw's and the antenna. those are SHORT antennas by cb standards. a 1/4 wave is about 9ft long. a full wave is around 36 ft.. so anything shorter than the 102" whips are prone to have less range. if swr check out. the board on the 18's and 19dx styles need to be resoldered from time to time. simple fix .. don't pay more than $8 to fix the radio...
Feb 01, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
Road noise
You will need to install a noise filter, you are getting interference from the Alternator in your vehicle.
Jun 19, 2010 | Cobra 29 LTD CB Radio
How do i do this?
the current power supply is constant,
{ coming straight from the battery supply}, you need to disconnect that wire and connect a wire coming from the ignition, using a circuit tester, locate a heavy wire that only lights the tester when the ignition is on. I would still recommend using a fusable link before bare connection. This will solve your problem, Cheers.
Jun 01, 2010 | Midland 1001Z 40-Channels Base CB Radio
I get static so bad that I can't squelch it down enough to get rid of the noise. Traveling out on the highway it usually works ok. But when I enter a town the static gets badusually around power lines. How...
You could install a filter in the line between the antenna and the transciever. I reccommend a high-pass or band-pass filter set for the 27 MHz band to remove any interference at different frequencies. Also, some older TVs can cause interference to CB radios if they are close. If this doesn't work, the radio may be poorly sheilded or your area may have implemented the broadband power line initiative (BPL). This produces a strong buzz of noise that obliterates all weak to moderate radio signals between 2 and 80 MHz (CB being at 27 MHz).
May 21, 2010 | Cobra 19 DX IV CB Radio
I have a pickup with a fiberglass bed cover, inside is a Cobra 29. When the k40 antenna is on the bedcover (magnetic mount w/ 6x6 inch metal plate glued to the bedcover) radio will give me an antenna...
Well, the k40 is designed for roof or trunk mount,you would not be getting a good ground,plus you would be getting feed back from cab,no good transmit or receive. Get a good 102" fiberglass or steel whip that's bumper mount,mount it on right rear bumper and you will be good to go.
Mar 28, 2010 | Radio Communications
Static or interference
Turn on the radio. If there is noise, disconnect your antenna from the back of the radio, but DO NOT KEY UP. If the noise goes away, it is coming in from the antenna. if the noise is still there its coming from the power source.
If its coming from the antenna, it could be something near by RF interference. If its not that then there could be something wrong with the antenna, or most likely bad coax. If it does it when windy, there could be a short, or gash in the coax, and makes it short on something
If its coming form the power line, the power supply may be bad, and ready to die. try another power source.
Mar 15, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Terrible static
What type of antennae are you using? If you are using an aluminum or stainless steel ant, I would suggest switching ti a fiberglass ant. It sounds like the metal ant is picking up the ambient voltage from the lines. If you are using a fiberglass already let me know, as you may have a more serious problem. Good Luck and I hope this helpsd L8R
Sep 17, 2007 | Cobra 29 LTD CB Radio
Uniden pc 78 elite cb
Hi, This is a link to your old post re SWR 3....http://www.fixya.com/support/t180697-pc78_elite_cb As stated SWR 3 is too high, it should be 1.5 or lower. Fiberglass antenna are kinda notorious in setup and experience wise have not performed well or at all. Maybe you should try a different antenna (metal rod). Some good brands/models I have tried with very good results are K40, Hokushin, Comet, Oscar, Maldol, Daiwa. To check if you can receive, stick an ordinay length of wire ('bout 9' long) at the center of your radio's connector. RX should work (pls don't key the mic or TX).
Aug 12, 2007 | Uniden PC78ELITE 40-Channels Base CB Radio
Cobra 19 DX IV CB Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
