Question about Brother Office Equipment & Supplies
I HAVE A MFC 8220 AND CANNOT SET THE FAX TO PICK UP WHEN SOMEONE SENS A FAX THE FAX IS ON A SEPERATE LINE BY ITSELF
    Genius:
  • 2,120 Answers
You need to enable AUTO ANSWER in the menus.
Try unplugging an replugging to see if auto answer comes back on.
Posted on Sep 01, 2008
How do i get dial tone on fax machine
first, as a tech, i would make sure your phone jack works, then also make sure the line is plugged into the "line" jack on rear of fax. if those two steps are verified beyond a doubt, press your "hook" button and listen for dail tone. if none, pick up handset and listen. if you get tone on handset, then your speaker is disconnected. if you don't get a tone either way, then chances are you have a bad "NCU" board.
good luck,
razors
Oct 19, 2011 | Brother MFC-8220 Fax
How to set the date and the time in brother fax mfc-8220? what's the steps?
Your MFC displays the date and time and if you set up the Station ID
it prints on every fax you send. If there is a power failure, you may
have to reset the date and time. All other settings will not be affected.
1 Press Menu, 0, 2.
2 Enter the last two digits of the year.
Press Set.
3 Enter two digits for the month.
Press Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day.
Press Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time whenever the MFC is in
Standby mode.
thx, if this helps please rate :)
Jan 27, 2011 | Brother MFC-8220 Fax
Unable 2 send or recive fax
Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 15, 2010 | Brother MFC-8220 Fax
We are not receiving faxes...telephone rings but doesnt pick up
the fax may be out of ink, out of paper , or set in the manual mode , I would think its set in the manual mode and has to be reset in the auto mode, go to settings , receive mode and set to auto.
Apr 08, 2010 | Brother MFC-8220 Fax
Having problems with long distance fax transmissions - receiving number not receiving fax. Fax machine: Brother MFC-8220.
Is the 1 placed infront of the number, is the line part of a PBX system requiring to dial a 9 to get a outside line.
Aug 13, 2009 | Brother MFC-8220 Fax
You have to answer the hone to recieve the fax
Try unplugging the power cord for 10 seconds to reset the machine.
Scroll through the menus and set your machine to AUTO or AUTO RECEIVE.
Nov 25, 2008 | Brother MFC-8220 Fax
It answers for a second and then disconnects the call.
Make sure the phone line is ANALOG. DSL makes fax machines go nuts.
Aug 29, 2008 | Brother MFC-8220 Fax
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
F ed up fax mahine
Is the hand set on correctly? (unlplug it if you can)
make sure the phone line is plugged into the LINE port.
Unplug the power cord for 10 seconds.
Jun 23, 2008 | Brother MFC-8220 Fax
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
