Question about HP PSC 2210 All-In-One InkJet Printer
Faxing I cannot leave the phone jax connected to the printer. If I do the phone will ring only one time. When you try to answer it you get nothing. When I need to send a fax I have to plug the wall jack in. Help
  • 234 Answers
If you have a distinctive ring pattern activated in the same phone line you will be able to receive fax, Voicemal, and phone calls without disconnecting the fax cable on the All-In-One.
When you have activated a distictive ring pattern.
Then you need to set the rings to answer in your fax machine to The ring pattern which was provied by your telephone company.
In the Menu/Setup>Goto> Basic fax setup> Then> Set it to either double ring or triple ring which ever is aplicable. Then Raise the rings to answer in advance fax setup to 5 or 6 Rings
The rings to answer in you phone or answering machine should be set to 4 (Always lower then that of the fax)
Good Luck
Posted on Aug 28, 2008
My phone calls are only going through my fax how do I disconnect that to get my phone calls through my phone
Please refer to the Lexmark Pro700 Series User's Guide for a more comprehensive instructions on how to setup your printer for faxing. The Guide includes some tips on how to configure your printer when connected to a fax line being shared by the phone or answering machine.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Oct 07, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Not faxing on 2410 all in one hp printer
make sure that youre using a regular line not dsl or voip line make sure youve connected it to the right port it should be line 1 connect the printer direct to the phoneline check settings "rings to answer" must be set to 3 ring you should have distinctive ring it must be set to all rings check fax speed it must medium then run a fax test all of these are under fax setting on your printer send fax tp 1800-hpfaxme,if recived a reply your good to go...otherwise call hp support...
Mar 30, 2011 | HP PSC 2410 All-In-One InkJet Printer
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hi i can't send and receive faxes. My phone
Here's the link to download the Lexmark X7170 User's Guide: http://bit.ly/c8EHEn. Go to Faxing for the instructions on how to go through the settings on the printer. For setting the printer to ring to answer at 0, set it to pickup on the 1st ring. To turn off the distinctive ring, set the ring pattern to any. Hope this helps.
Jul 15, 2010 | Lexmark X7170 All-In-One InkJet Printer
Can not add my fax machine ???
your connection for the printer is ok, is your phone jax connected correctly. from the wall to back of printer (in)....and from (out) printer to (phone line in) pc....did you download the brother's printer/fax software completly...when done the test page would print and say fax is ok or not....if ok this will allow you to configure the time/date and rings to answer (your fax # is your home #) note if you have an answering machine and it picks up on the 5th ring (you will be better off setting the fax to pick earlier then the 5th)
May 29, 2009 | Brother Office Equipment & Supplies
Faxing using voip phone service
We found out that the machine requires a dedicated analog line, so we won't be able to use it on a voip system.
Jun 16, 2008 | Canon PIXMA MX700 All-In-One InkJet...
When faxing, what is Error 387? Can fax other places, why not this place?
Specifically, error code 387 on that machine is : Try to send the fax at a different time when telephone line conditions have improved. There is nothing wrong with your machine that I can tell from your description. It sounds like it is trying to handshake, fax term for connect, but does not complete. I had the same thing happen to me yesterday with some very important papers. I even called the person at the other end and they said they had been receiving faxes ok. Took me 4 tries but finally went through. It's just the phone lines. Keep trying. It can take several tries. If this helped please rate a big 4 fix ya. If you can't get through no matter how many times you try just post a comment and I'll be happy to come back and help you out.
Mar 25, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
How do I connect the wires for faxing?
there are two phone jacks at the back of the printer one is for line another one is for external device such as answering machine make sure you connect your phone line to the line jack at the back of the printer and try it should work. and also try to fax the right no.
Dec 12, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
95 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
