Seagate 500GB FreeAgent GoFlex Hard Drive Logo
Posted on Jul 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Latitude E6400 and I'm trying to boot and load a Windows 7 from my Seagate FreeAgent GoFlex Pro. My computer recognized the hard drive but is loading a Windows Boot Manager. The Boot Manager gives me this : File: \MiniNT\Windows\System32\boot\winload.exe Status: 0xc000000e Info:The selected entry could not be loaded because the application is missing or corrupt. I have checked and the hard drive isn't corrupted and if I don't boot from the hard drive, my computer runs fine. What do I need to do to access my hard drive?
Gilbert Jalimao
Level 2:
Sergeant:
  • Expert 243 Answers
  • Posted on Jul 08, 2011
Gilbert Jalimao
Expert
Level 2:
Sergeant:
Answers
243
Questions
0
Helped
42047
Points
763
If you want to use another hard drive you have to install a new Windows Operating System
2answers
Using Seagate Goflex Hard-drive 750 GB, upgraded Windows 7 to Windows 10. get message Seagate harddrive not supported on Windows 10. Is there a solution to fix this? Russ
Will My Hard Drive Work With Windows 10? - PC Magazine
www.pcmag.com > ... > Windows 10
PC MagazineJul 29, 2015 - Some drive manufacturers have gone through the Windows 10certification process, ... Seagate products are NOT compatible with Windows 10.
Seagate GoFlex not compatible with Windows 10 - Microsoft Community
answers.microsoft.com/.../windows/.../windows_10-hardware/seagate...n...
Aug 4, 2015 - Since, the Seagate Dashboard is not compatible with Windows 10, let's try ... 10 with my Seagate FreeAgent Go Flex Home 1T external hard drive - model ... Windows 10 Backup Not recognizing Seagate Desk External Drive ...
Aug 18, 2015
Windows 10 Install- Now Seagate External USB 3TB HardDrive ...
Aug 13, 2015
Seagate 3TB external hard disk not working with Windows 8 ...
Jan 26, 2013
More results from answers.microsoft.com
When I plug it into my computer, it says 'access denied' and prevents me from transferring my pictures to the goflex harddrive.
Sounds like Microsofts nuts user file access system. Try connecting to a non-windows machine i.e Linux - if you see the files, that's your problem.
My seagate freeagent goflex 1tb hdd appearing as local disk in my computer... the autoplay dialog window doesn't come up when the drive is connected..
AUTO PLAY DIALOGUE IS OFF IN YOUR OPERATING SYSTEM
ENABLE AUTO PLAY
WHAT OS YOU ARE USING
OR CHECK BELOW LINKS
Windows 7, Windows Server 2008, Windows Vista, Windows Server 2003,or Windows XP
Fix it for meTo disable or enable Autorun automatically, click the appropriate Fix this problem link. Then, click Run in the File Downloaddialog box and follow the steps in this wizard.
Disable AutorunEnable Autorun
Fix this problem
Fix this problem
Seagate Freeagent goflex not detecting
It sounds like the drive is failing. So you will need data recovery services.
A remote service is http://FreeDataRecovery.us
1helpful
Hi,how can i format my seagate freeagent goflex 750 to fat32 ?
Welcome to Fixya. Once you connect the harddrive on the computer go to my computer or computer then right click on the seagate drive then select format. On the window that will pop out on the screen select Fat32 then format the drive. Please use windows xp or 7 because vista don't have fat32 but exfat.
Thanks
My mac does not recognize my seagate goflex drive anymore
Try the drive on another computer. If it is recognized there, you might be looking at a larger issue on your Mac. If it doesn't, the GoFlex's drive or boards may have failed.
I accessed my Freeagent goflex 1tb on my laptop the first time. but when i tried to use it again, a display shows that the drive is not accessible. access is denied. what can i do? i'm using windows 7...
Switch off and on your Freeagent, that should cause a driver to be loaded. If no change reset your Laptop. You should also upgrade to Windows 10, since WINDOWS 7 IS NO LONGER SUPPORTED.
3helpful
Can you use a Seagate 500GB FreeAgent GoFlex external Hard Drive with ready boost in windows 7?
Yes, but because it's a hard disk and has low transfer speeds it will actually slow down the pc instead of making it work faster. Ready boost is designed to be used only with memory sticks of the latest generation.
2helpful
The Samsung Freeagent GoFlex external hard drive is not recognized by Windows 7 OS. I tried to initialize disk under computer management / storage / disk management and got the cyclic redundancy check...
This is a good read on what this error actually means:
http://www.softwarepatch.com/tips/cyclic-redundancy.html
What I recommend is reformatting the drive under Computer Management, and seeing if that fixes the problem.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
