Heater when I turn my thermostats on there is a burning smell ?
  • Anonymous Apr 10, 2009
    the delonghi gas heater doe not work
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This should be normal for the first time every year as the dust collects in the heat chambers and airconditioning coils only for atleast 30-minutes and smell like dust..and not electrical wires..!
Posted on Sep 09, 2008
Burning smell in turn on the heater and out side to 2004 Honda accord LX 4 Door
Can you tell if the smell is coming more from the outside(under the hood), or the inside? I can only guess from the info so far. If the smell is from under the hood turn the heater on recirculate and you won't smell air from outside the car. Not sure where you are from, but here in New England it is time for mice inside the heater boxes.
Dec 06, 2014 | 2004 Honda Accord
Tip
Sauna Heater
Oil and Gas Sauna Heaters
Oil and gas heaters are the least popular heaters used in saunas.
One reason is because they're relatively inefficient compared to the others.
Some people even complain about the odor associated with the burning fuel. If they're properly vented, oil and gas heaters should have little or no unpleasant smell
Electric Sauna Heaters
Electric heaters are the most popular used in saunas.
They're easy to control with user friendly touch pads that include a timer and thermostat, and light switch,
They're also efficient and cost just pocket change to operate.
Electric heaters have controls that include a timer, thermostat, and light switch.
Wood Burning Sauna Heaters
If you have a house in the country or easy access to fire wood, a wood burning heater is a great choice for a sauna.
A wood heater may also be a good choice if you have an outdoor sauna.
Wood burning heaters don
on Jan 08, 2011 | Heating & Cooling
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
Heater is not working. No heat coming from it.
if u can smell coolant burning when you try to turn on the heat, it would be the heater core. i would first check the coolant level and change the thermostat. if coolant is full and clean with a new thermostat u have a bad heater core
Jun 15, 2011 | 1999 Ford Taurus
I have a Honeywell Oil filled heater, HZ 680 series. When both switches are turned on, they light up but there is no heat. Also, a funny smell then the switches automatically turn off. Is there anything...
These heaters last about three years,and are throw aways,unless you have some in the ole shed like I do.Checking the switches is the first thing to do,remove them to see if they are burned up on the other side where the connection is.If they are,that could be the smell,or the thermostat is melted down,and smelling,again,throw away,,or save it,and buy a new one,and you will have parts for when it goes out,if the switches are melted down,a compatible switch,if found,can be replaced in the heater,but something made the switches melt down,most likely a heating element in the tanks,non replacable.
Jan 05, 2011 | Honeywell HZ-680 Oil Filled Radiator...
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
4) Bad upper element. Test upper element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Nov 22, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Burning smell from oil heater
Pull the controls off the front,and inspect the thermostat connections to see if they are burned up,also the other switches will do the same thing.If you can`t see a problem,then the element is burned out,throw it away and buy a new one.
Sep 24, 2009 | DeLonghi 9707 Oil Filled Radiator Heater
Electrical smell
did you recently screw or nail something to the wall?do you have the old fabric coated wires?
Feb 26, 2009 | Honeywell Electronic Programmable...
Electrical burning smell in house
Mhenn, It is my guess that the 'electrical burning' smell is from your heating system. Since there is no smoke and the walls are not warm.... then there is no real problem. The smell maybe just dust has collected in the duct work that is burning off the central heating systems electrical heat strips. If you have electrical heat strips then that may be the problem. If you have a central gas heat system, it may be the same type problem. Hope this helps you. Henry
Feb 05, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
265 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
