Hi.
Disconnect power, then locate the access to drain pump. On GE top loader the pump access is usually at the back, sometimes at the bottom. Disconnect the hose from the pump and remove any blockage in there.
Check also the height of the drain hose at the back and ensure that the hose is set according to manual. An drain hose set incorrectly will result in drain problems.
If that does not fix the problem, clean or replace the pressure switch and pressure hose that detects water level determining when to start and stop draining.
Regards.
Ginko
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
heatman101
heatman101
please
