Question about Olympus C-7000 Zoom Digital Camera
Balance Function When and how would I use the One Touch White Balance Function?
    Master:
  • 852 Answers
This function is useful when you need more precise white balance than the Preset White Balance can provide. To set the optimum white balance for the shooting conditions, point the camera at a white object under the light source that you want to use, and press the OK button to set the white balance.
Posted on Sep 04, 2005
SOURCE:
One touch white balance
i have the e-500 and can only register one at a time. once you set the white balance using the one touch button, it stays that way until you one touch again or custom reset. however it may be possible to save to 'my mode' 1 or 2 ... or even 'custom reset' 1 or 2. according to the manual on page 119, it saves your wb setting and most of the other changes you have made.
reset camera... soft reset. Mode Dial to P, press Menu, right arrow (AF button), to card setup, down to custom reset, right to custom reset, OK, up to YES, the OK
Sep 24, 2008 | Cameras
white balance... you can go through the white balance menu and change the custom to whatever temperature you want... camera 1, wb, cwb, right to change temp. you can also change the red and green on the presets by pressing right at each preset temperature.
now if you are using one touch wb, then put the wb on one touch, then in camera ready hold in the one touch button and press the shutter button while pointing to white or gray card. this is stored as one touch until one touch is done again or the camera is reset. turning off camera will not reset the custom wb.
so to access your stored one touch put wb on one touch because this stores that last white balance done
Sep 22, 2008 | Olympus EVOLT E-500 Digital Camera
Flash fails to function.
Can't help on the flash problem. I have same problem and am loking for he solution also, but I can help o the "AWB" issue. AWB stands for Automatic White Balance. You can change in the "Menu" - "White Balance" function.
Feb 14, 2007 | DXG Technology DXG-305V Digital Camera
What is the function of the custom white balance setting?
Custom setting mode allows a user to calibrate the camera to a specific light condition. Color reproduction may be inadequate with preset white balance settings in mixed lighting condition or when critical control is needed. You can calibrate the camera's white balance to the specific light condition (color temperature) so that the lighting of the selected area is neutral.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Limited setting for White Balance.
Hi: So you bought the camera but didn't make a good choise :) Yeap, the "four only options" in the Sony F55 in the White Balance Function are what you said. You have to have that in attention when buying a Digital Camera. About the White Balance > Hold, the intention is to adjust the white balance acording to an object. After you select the option, to use it you just have to point the camera to the object, press half off the shutter button to focus, then you chose the angle and press the rest of the shutter button. On the other cameras those options improve the quality of the skin tones and colors of your subjects reduzing color temperature. Regards
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder and monitor. You can choose mode from Auto, Preset 1, Preset 2, Custom, One-touch, and White balance compensation.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder/monitor. You can choose mode from Auto, Preset and One-touch.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
White Balance
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
White Balance
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder and monitor. You can choose mode from Auto, Preset 1, Preset 2, Custom, and One-touch.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Olympus C-7000 Zoom Digital Camera Logo
314 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
