Question about Whirlpool Washing Machines
WATER IS LEAKING OUT UNDER MY WASHER I THINK ITS THE PART THAT THE DISCHARGE HOSES CONECT TO IT IS PLASTIC WITH AGEAR IN IT
  • 639 Answers
Dear jwarbonnet,
ngfam at you service!
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
Why 4E error code keep appearing on my Samsung washing machine
The 4E error indicates that the washer hasn't detected enough water coming into the unit. The problem could be in your incoming water line (low water pressure), the washer hoses, the inlet valves, or the sensors that detect the length of time to reach a specific amount of water in the washer. It can even be caused by having the outlet hose positioned too low in the discharge pipe or sink.
First check the obvious possibilities: make sure that the shut-off valves have been opened. If you hear water running into the washer and then into the discharge plumbing after a few minutes, raise the end of the discharge hose to a level above the washer fill level.
Shut-off the incoming water and remove the washer fill hoses. Place a bucket under the hoses and open the shut-off valves. Check that you have good water pressure; the washer is looking for the tub to fill in about 8 minutes. Then turn off the water. Clean the filters in the hose at the shut-off valves and the ones inside the washer at the inlet valve. You may want to replace the washer fill hoses; some anti-flood hoses will constrict if they detect a leak and limit the water pressure.
If the water flow at the hoses is good and isn't exiting the washer, then the problem is either the inlet valve or the water flow sensor. Does any water reach the tub? If it doesn't, check the inlet valve and make sure that it is getting the proper electrical signal from the control unit. If water is reaching the tub, then the problem in the flow sensing system. Some washers use an air tube that helps check the pressure in the system. If this tube is leaking or clogged, the sensor will give incorrect messages. Other systems have a small switch that moves as the water passes through the inlet valve. This can fail.
There can be other problems that give the same symptoms. If you post the model number of your washer, I may be able to point you to the correct diagnostic steps.
Nov 04, 2015 | Samsung Washing Machines
Water leaking on floor? How to fix
Depending on how old the unit is will depend on where to look for the leak. You have an incoming water line, a motor (with an impeller) and a discharge hose. First look at the hoses, motor assembly and areas under the washer tub for tell tale signs of leaking. Look for staining, usually a line like white powder will lead you to the leak. If none is found, start with the incoming line; first look at the valve that feeds the dishwasher, see if that is leaking. if it is, it will have to be replaced. Look at the feed hose to the dishwasher and see if it is brittle and cracked, if it is, replace it.Look at the discharge hose for brittleness and cracking as well, also check the connections to insure they are tight. If the hoses are found to be in good shape then look at the motor. There is a gasket that is in between the motor housing and the washer, see if it is leaking if so, replace it. You will have to remove the dishwasher to access the motor so be prepared to spend some time to complete this. Good luck and I hope it is just a hose issue.
Oct 20, 2014 | KitchenAid Dishwashers
After about 10-30 minutes after cycle is finished there is water around and under washer
Your discharge hose is leaking. Check the hose itself, of course (for hoses), but the problem is most likely a loose connection of the discharge hose to the discharge outlet.
To inspect these items, you'll need to remove the back cover of the unit
(typically 11/32-in nutdriver), and follow the discharge hose to the discharge outlet. You may find that the hose clamp needs to be replaced, or that the
end of the hose is deteriorated, and needs to be cut off an inch shorter, and the hose clamp re-applied.
May 22, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Washer discharge hose had a couple of leaks in it. Replaced hose and tighten clap. Now there is water leaking from under washer when it is filling or pumping out water. Can't see where its coming from. I...
This could be due to a lot of things. One is the work that you did could have loosened the hoses in the machine. In order to see what the issue is, you need to drain it all the way with a wet vacuum cleaner and lay it down. Then you can see all the hoses and pump etc.
Nov 13, 2017 | Maytag PAV3240A Top Load Washer
Washer leaking water while spinning
Check the drain hose where it leaves the machine, if the square section of it is not in the plastic housing it will cut on the cabinet, if this has happened replace the hose they are difficult to repair, Other possibilities, pump is leaking, and check that the inlet hoses are not leaking and have washers in every connection.
Apr 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a 21 year old Kenmore washing maching (model 82873800). It is leaking when it is filling up. The water is not coming from the hoses or the center shaft. When I lean the washer over, I can reach...
I'd go to the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.82873800%29
and check the sub-components lists for a gasket or part under the tub that keeps the water from leaking.
With a 21 year old washer, it's likely that one of the rubber or plastic gaskets has finally worn.
Sep 20, 2009 | Kenmore Washing Machines
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking from white plastic peice under washer
If this piece had 2 hoses attached and slides onto the motor, then it is the pump. you will need to replace it. Part # 3363394 available both new (27.99) and used (9.99) from timerking.com Hope this helps!
Jan 07, 2009 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
