Question about HP LaserJet 1300 Printer
Lj 1300 doesnt spin up just blinking bottom yellow light
Replaced fuser film and yellow attention light just blinks no motor or gears turn. Did the engine test and triped interlock and front door switch nothing will turn. The only thing not sure of is exit sensor and the hp diagram poorly shows how it goes in. Ive been fixing printers for years but this has me stumped. HElP!!!!!!!
  • 138 Answers
My guess is that the wire from the photocell at the rear of the fuser (exit sensor) is not seated properly. The connector on the board side also has a nasty habit of the pins pushing down into the board in the connector. Put check the connections carefully from the exit sensor to the main boad. If it has pushed down, it can be pulled back up without ill effects using a small pair of hemostats..
Let me know what you find. Hope that helps you.
Posted on Aug 26, 2008
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Hi my lj 1010 printer is not initialising at all When i trun on the printer after blinking all the lights one by one its red light keeps glowing There is no gear movement at all I have good experience in...
try to do cold reset:
  1. Turn the printer off.
  2. Press and hold down the green GO button.
  3. Turn the print on while continuing to hold down the green GO button for at least 5 seconds, but no longer than 15 seconds. During this process, the attention LED (!) turns on.
  4. Release the GO button. The printer is ready if the green ready light is steadily on.
Dec 17, 2013 | Office Equipment & Supplies
I have hp lj 1300 printer befor problem fuser sleeve damage that is repalacing and fixing but now not working only read light bilnking how can repair sir
red light blinking gnerally for
1.door open
2.no cartridge
3.fuser element blown( measure fuser element with volt meater)
4.sensor error
and so many
these are the mejor.
Jan 09, 2011 | HP LaserJet 1300 Printer
My Hp 1300 laserjet printer doesnt get ready after initializing but giving orange blinking light, what could be the solution because i have checked the toner is in properly .
Remove the paper and re-loaded it, if it still giving you the blinking, turn it off and hold the go key down while turning it on then release it, this should rest any errors, worse case you have a bad fuser.
Jun 15, 2010 | HP LaserJet 1300 Printer
1300 Printer prints roller marks only on one side. have tried cleaning roller & changing cartridge.
If it is not the cartridge check the fuser. Open the back access cover shine a light in and look for wear marks on the grey fuser film. If it is worn the fuser film is worn it should be replaced.
Jun 09, 2010 | HP LaserJet 1300 Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Attention Light Is Rapidly Blinking Orange
sorry I got it, usually you may try:
1) check all paper road no paper inside include the area betweem input tray and cartridge unit the area wetween cartridge and fuser unit and output tray.
2) check 4 sensor input sensor near the input tray roller, marging sensor between input roller and cartridge unit, cartridge sensor at oneside of cartridge unit body, fuser sensor near fuser roller. usually need to clean or adjustment the position.
3) check input roller and cartridge unit and fuser unit at running condition when the power on.
anyone nothing running show error light blink, also show the hardware trouble if all sensors are normal.
Dec 24, 2008 | HP LaserJet 1300 Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
HP 1300 LJ Fuser Film
If you didn't have the orange light to start with and were replacing the sleeve due to a torn or damaged sleeve it sounds like you haven't plugged everything back in. The Error is an electrical fault with the fuser circuit.
Verify that all wires are plugged back in. Two areas to pay specific attention to are as follows. (1.) BOTH slide clips witth wires that you removed on the upper fuser edges to mount the new sleeve. Thats the connections for the ceramic element. If you get to having to uninstall and check the fuser, put an ohm meter on both ends of the element to ensure it's not shorted. My meter when on ohms has a beep when the leads are touched together when the meter is measuring ohms. Check for the beep when touching both ends of the element and that will prove the element good.
(2) On the board in the base of the machine, there are some plug in connections on the lower board very close to the rear edge and just about centered left to right. It's a cluster of about 3 or 4. Unplug the connections and pay close attention to the height of the pins inside the connection. One of those connections has a nasty habit of the pins slidding through to the other side and not making good contact. If I remember right its the right hand connection in the cluster or the one next to the right one. You can use the connections rest to it as a visual referance for the height. If the pin or pins have pushed down, carefully pull them back up with needle nose pliers or tweezers and replug the connection back in.
Hope that helps you. Just in case, heres a free manual PDF link to use to resolve. It's a 1200 manual as the 1300 wasn't listed but the processes are identical. Most of the parts are the same but check first before ordering any parts.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%201200%20Series%20Service%20Manual.pdf
Jul 16, 2008 | HP LaserJet 1300 Printer
Fuser Gear Md No. LJ 7416
You will need to purchase these gears from a brother dealer but I warn against just changing the gears you mention, fuser driver gear in printer frame will be ok unless chipped, but usally the big gear on the fuser goes as does a little white one next to it, and these are breaking becase the fuser is hard to turn, if you just change the gear, the fault will reappear after a little use, best bet is to replace fuser assy (approx $150)
Oct 27, 2007 | Brother MFC-8840D All-In-One Laser Printer
HP LaserJet 1300 Printer Logo
249 people viewed this question
Ben Johnson
