Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Exhaust Hose Are the exhaust hose and intake hose exactly the same size, i.e. interchangeable? I'm having trouble fitting it onto the exhaust outlet.
  • fannymack Sep 15, 2008
    No electrical power
No, they have different fittings.
Posted on Aug 31, 2008
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
Jun 09, 2016 | Danby Heating & Cooling
Have an ss carb e type an a single outlet pingel pepcock have a vent line from carb what do I do with the vent line
Here's S&S's manual for the Shorty Carbs (both E & G):
http://www.sscycle.com/files/7913/7033/9802/51-1012_carb_e__g_series_shorty_carburetors_installation.pdf
On page "10", it states, "Slip fuel overflow hose onto fitting on carb bowl and neatly route behind pushrod tubes. On a big twin model, hose should go toward back
of engine. On a Harley-Davidson Sportster model, hose should go toward front of engine. Exit end of overflow hose must extend down
below engine and away from exhaust pipes."
This is the only "vent" hose (actually, a fuel overflow hose) that I know of.
Aug 24, 2014 | Motorcycles
Vacuum hose
I never heard of a vacuum line going from the throttle body/intake manifold before but I have never worked on a Kia. Disconnect the hose at both ends have some one take you to ace hardware they have automotive vacuum hose by the foot bring your old hose with you so they can cut the proper length and girth of your original hose and pop the new one back on. It might be hard to fit the new hose back onto their fittings i usually lightly oil the surface that the hose goes over with engine oil so it goes on pain free remember lightly oil. good luck.
Mar 27, 2014 | 2001 Kia Sportage
2002 chevy tahoa 5.3 codes p0171 0174
Trouble Code: P0171
Fuel Trim System Lean (Bank 1)
Possible Causes:
Air leaks in intake manifold, exhaust pipes or exhaust manifoldFuel control sensor is out of calibration (ECT, IAT or MAF)Low fuel pressure (fuel filter clogged, pressure regulator failure)One or more injectors restricted or pressure regulator has failedHO2S element is contaminated, deteriorated or has failedVacuum hose is disconnected, broken, leaking or loose.Trouble Code: P0174
Fuel Trim System Lean (Bank 2)
Possible Causes:
Dec 27, 2012 | Cars & Trucks
Will a 1993 mercury engine fit in a 2002 grand marquis
Without seeing the two, I would say no.
You would have to check motor mounts, bell housing, exhaust pipes, and then all of the emission components and wiring to find out.
Even the radiator hose outlets.
A salvage yard should have an interchange book to help tell you.
Jul 15, 2012 | 2000 Mercury Grand Marquis
Where is the thermostat located on a 2001 pontiac grand am SE, 6 cylinder automatic
Follow the hose from the coolant reservoir to the engine. The thermostat is behind the housing where at hose connects. Below are instructions from autozone.com. Recommend you also read my post at http://www.fixya.com/cars/r5929960-s_thermostat, and thanks for using FixYa.
3.4L Engine
  1. Drain the cooling system.
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat
  7. Clean the mating surfaces.
To install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet. Tighten the fittings to 15 ft. lbs. (21 Nm).
  5. Install the air cleaner.
  6. Fill the cooling system.
  7. Inspect the system for leaks.
Dec 20, 2010 | 2001 Pontiac Grand Am SE
Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
Jul 09, 2010 | Amana Heating & Cooling
EGR VALVE 1999 MERCURY COUGER
SECTION 303-08: Engine Emission Control 1999 Cougar Workshop Manual REMOVAL AND INSTALLATION Exhaust Gas Recirculation (EGR) Valve Removal
  1. Remove the air cleaner outlet tube.
    1. Disconnect the intake air bypass hose.
    1. Disconnect the positive crankcase ventilation hoses.
  1. Disconnect the tube from the exhaust gas recirculation valve.
  1. Remove the exhaust gas recirculation valve.
    • Disconnect the vacuum hose.
Installation
  1. sxu~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: When cleaning the gasket faces, do not allow debris to enter the intake manifold or exhaust gas recirculation valve.
    Clean the gasket faces of the intake manifold and exhaust gas recirculation valve.
  1. Install a new exhaust gas recirculation valve gasket.
  1. Position the EGR valve and install the bolts.
    • Install the vacuum hose.
  1. Connect the EGR tube.
  1. Install the idle air control valve. For additional information, refer to Section 303-14A . For additional information, refer to Section 303-14B .
Sep 15, 2009 | 1999 Mercury Cougar
Exhaust interchangeable
I think so as long as the engine size is the same. I'm not sure that Evo pipes will fit onto a TwinCam. I bought a pair of Screaming Eagle Slash Cut and they bolted right up no problem. Easy instal
Nov 20, 2008 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
Nov 10, 2008 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Heating & Cooling Logo
310 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
