Question about Olympus C-7000 Zoom Digital Camera
AF Area function
What is the AF Area function?
    Master:
  • 852 Answers
You can use the AF Area function to change the location of the Auto focus mark to the left, right, up, or down depending on the location of the object that you wish to focus on.
Posted on Sep 04, 2005
HOW DO I SET MY CAMERA TO AUTO FOCUS
The D90 has three different autofocus modes. In the AF-S mode it will not shoot until it has focused. In the AF-C mode it will shoot when you press the shutter release button even if has not focused. In the AF-A mode the camera switches between the AF-S and AF-C modes so either can apply.Also, bear in mind that the camera doesn't really know what you're taking a picture of. It may focus on something other than your subject. If you're in the single-area AF mode then you control which of the eleven focus points the camera uses. In any of the dynamic-area AF modes the camera decides.For full details on how the various modes work, please consult your manual. You might also check out the Nikon D90 video tutorial.
Apr 24, 2012 | Cameras
What type of lenses fits this camera
Lens mount Nikon F mount (with AF coupling & AF contacts)
Lens compatibility • D-type / G-type AF Nikkor (except IX-Nikkor): Autofocus and all functions possible
• PC Micro-Nikkor 85mm f/2.8D: Usable in Manual exposure mode
• AF Nikkor other than D-type (except AF Nikkor for F3AF): All functions except 3D Matrix Metering possible
• AI-P Nikkor: All functions except 3D Matrix Metering and autofocus possible
• IX-Nikkor: Cannot be used
• Non-CPU: Usable in Manual exposure mode (exposure meter cannot be used)
Electronic Rangefinder usable with lens with maximum aperture of f/5.6 or faster.
Jul 04, 2011 | Fuji FinePix S2 Pro Digital Camera
How to get several focus points in a d7000 viewfinder?
Hi, On the D7000 you need to press the button on the side of the camera that's in the middle of the AF/M switch and then you use to switch to decide whether it's in 1 point autofocus (hence forth called AF), 9 point dynamic area AF, 21 point dynamic area AF, 39 point dynamic area AF, 3D tracking AF or auto area AF. If you need more help with switching AF modes let me know and I can help you out =)
May 16, 2011 | Nikon D7000 Digital Camera
Wrong icon when selecting dynamic area
The D40 Dynamic area focus starts on the centre AF area then moves the focus to follow the subject.
The camera has followed something to the right and selected the right focus area.
This is normal.
You could select Single Area in the menu and move the area back to the middle using the rear AF Sensor Selector.
Jul 05, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Auto Focus stopped functioning and there is no AF point display
Could be that the electrical contacts on the lens / body need gentle cleaning - try that.
Jul 22, 2017 | Tamron AF 28-80mm Lens
Manual focus points 40D
Try checking C.Fn III, 3: AF point selection method. Yours might still be on option 2.
0: Normal - Works by pressing the AF Point button and then the Multi-controller.
1: Multi-controller direct - Press the multi-controller to directly select an AF point (without first having to press the AF Point button). Pressing the AF button reinstates all AF points for auto AF point selection.
2: Quick Control Dial direct - turn the Quick Control Dial to select AF points. In this mode, AF points will not be displayed on the LCD panel.
Jul 18, 2008 | Canon EOS 40D Digital Camera
Nikon D80
Hi taylorrm, I don't know if you have a solution to this but sometimes the AE-L/AF-L but gets pushed which is the auto focus lock button then the shutter release button cannot be used to focus and yu have to reset by pressing it again.  Even though it's confusing at first it's a feature along with the AE/AF Lock to try out to lock your focal area on a subject prior to shooting.
To sbhoward5, check to make sure the switch on the camera body is switched to AF instead of M mode(looking at the front it's on the lower right hand side below the lens release button), which sometimes happens when changing the lens - so then the mode selected is in P,S,A, or M modes on the mode dial. happy shooting,
randy320sgi
Jun 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5) Non-CPU: Can be used in mode M, but exposure meter does not function; electronic range finder can be used if maximum aperture is f/5.6 or faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
Feb 01, 2008 | Cameras
Brother MFC-425CN
AF after cleaning cycles??????????????????????????
AF means that the scanner flatcable is not connected to the main pcb (When powering up you should hear a grinding sound from the scanner area). Open the scanner cover as for changing the ink carts. Open the small cover (looks like a " L ") and connect the white flat cable simply by pushing it into the main pcb.
Oct 25, 2007 | Brother MFC-425CN Multi-Function Center...
Af area memory
Perhaps you're doing something wrong or skipping a stage in the configration. You can find the exact way to change the AF area here: http://www.fixya.com/BrowseManual.aspx?prdid=293765&hlt=af+area&mnlid=740&__PAGED_=74 Hope this solves your problem.
Jan 13, 2006 | Casio Exilim EX-S500 Digital Camera
Olympus C-7000 Zoom Digital Camera Logo
43 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
