Question about ECM Giotto Espresso Machine
Ecm giotto repair
Hi Chort,
I noticed your post on FixYa and was wonder if you ever found a service/repair shop for you Giotto? My Giotto also needs work and I can't find a authorized repair shop. Any recommendation is appreciated.
Thanks, john
  • Anonymous Nov 29, 2008
    need repair person
  • okuraica Dec 25, 2008
    Is there ECM Giotto service in Los Angeles?
    Ogie
    Problem Solver:
  • 9 Answers
Jonny boy,,If you ever had a Macano box as a kid, tthe best man to fix the machine is you! Take many photos before opening the pipework. Clean out the scale and learn about your machine! No kidding, you brew a better coffee after that. You know ALL the functions after looking into the machine + ther are some ways to tweek it too. Steam press cam be set as well as water amount. I brwe a better espesso tha I get on town. Thick light brown crema. I gave upo with the dealer and hes so called repair people /// Olev
Posted on Mar 21, 2009
I turn the ECM Giotto on, the light comes on but the pump does not activate and no heat. 2 hours later it all works fine.
Try this open the steam valve when you turn the machine on, leave the valve open until it starts to hiss with steam, then turn off valve. If that works then the vent valve is sticking and needs to be replaced.
Oct 12, 2011 | ECM Giotto Espresso Machine
Giotto Premium problem...
Try to do a hard reset by unplugging the device from the power outlet or take the batteries out and wait for sometime to reconnect.
May 29, 2008 | ECM Giotto Espresso Machine
I need a thermostat for the Giotto espresso machine . Where can I buy one ?
Hi you called me, you can get thermostats at: 1st-Line Equipment. http://www.1st-line.com/ They have lots and lots of thermostats.
Feb 13, 2011 | ECM Giotto Espresso Machine
I have a Giotto ECM esspresso machine. it is approximately 3 yrs old. recently when i turn the machine on, it starts heating up, but it doesn't create any pressure. any suggestions how to fix this problem.
Hi
1 solution is your vacuum breaker valve is sticking. Try opening the steam valve and see if you can start to heat again. If it does just, replace your vacuum breaker valve.
Sep 20, 2010 | ECM Giotto Espresso Machine
Help w/ ECM Giotto. pump doesn't turn on when pulling lever
Replace the magnets in the water tank, the reed switch is not reading one of them, most likely the safety or bottom magnet.
Feb 03, 2010 | ECM Giotto Espresso Machine
Just replaced the head gasket of my giotto
HI
Make sure that the water level probes are touching the machine to ground themselves. Push down on the probes, and see if the machine comes on. With out looking at it I don't know what else to tell you.
Nov 21, 2009 | ECM Giotto Espresso Machine
Giotto pressure valve constantly on
You must have an internal leak and your machine will need to be serviced. If you can remove the top of the machine maybe you can see where the leak is coming from and may be able to repair the machine yourself.
Cerini Coffee
Espresso machine service and Sales
www.CeriniCoffee.com
Nov 10, 2008 | ECM Giotto Espresso Machine
ECM Giotto Espresso Machine Logo
383 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
